LTSpice anomaly. Same wire, different voltages. - Page 2 - diyAudio
Go Back   Home > Forums > Design & Build > Software Tools
Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
Old 1st February 2013, 06:55 AM   #11
Rundmaus's Avatar
Using the node highlight function, try to find out which parts of the circuit belong to the two nodes N023 and N032 - maybe that shows why LTSpice is confusing them...
EDIT: If you don't want to rely on the graphic interface, check the netlist file created by the schematic editor for the entries of N023 and N032 and find out where the two nodes are in the circuit.
Old 1st February 2013, 06:58 AM   #12
Mooly's Avatar
"Node highlight" ?
I've never used that and as a Spice newbie I'll have to look at how to do that.
Old 1st February 2013, 07:05 AM   #13
Rundmaus's Avatar
If a 'Newbie' anyway, better to learn the 'good' way and have a look at the netlist file!
EDIT: Just had a look at the LTSpice schematic editor and it does not seem to be able to higlight nodes. If you look at the netlist file (open the file using a text editor or let LTSpice show the netlist via the menu entry), you will find a line for each component:
[component name] [connection1] ... [connection n] [component properties]
Now look for N023 and N032 and check in the schematic to which components these two nodes are connected.
Old 1st February 2013, 07:13 AM   #14
Mooly's Avatar
Node 23 seems to be the emitter of Q7. When I tag the opamp line this node changes to from node 23 to node 24 !
Old 1st February 2013, 07:18 AM   #15
Rundmaus's Avatar
This hints at a problem with the schematic editor / user interface - the netlist is determined by the schematic and does not change unless you change the schematic, i.e. not by clicking/tagging anything. Looks as if the tagging function randomly selects wrong nodes when clicking anything.
Looking into the netlist will clear things up I hope.
Old 1st February 2013, 07:20 AM   #16
Mooly's Avatar
Thanks... I'll have a look later today when I have more time
Old 1st February 2013, 09:04 AM   #17
just another
wintermute's Avatar
Definitely looks like a bug to me!!! It shows 7V when I hover over any point on that line. If I click on the lower part it puts 7V If I then click on the upper part, it puts 34mV (and the lower one changes from 7V to 34mV.
I deleted the two tags and did it again. this time it started with 7V and then when I clicked above it got -652mV... (for both places) very odd!!
and yes node 023 is the emitter of Q7!!
I tried dragging R29 to show that there were no breaks in the line, and now I cannot get a tag anywhere on that non-straight line it just gives ???! I suspect that there is a bug in the interface that is not properly picking up the co-ordinates of the mouse when you click to add the tag. It is certainly reproducable with the model you have attached though, so should make things easy to report if you want to do a bug report!
edit: I did it one more time and this time it was -2.32V and node 022 which I think should be the -ve input of the opamp which it is now showing at 7V and node N032!! It seems this time it has swapped the negative input and the output!
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 1st February 2013, 10:15 AM   #18
jan.didden's Avatar
Well where is V(n23) in the schematic?
jan
Music is dither to the brain; lets me think below the usual chaos - me
Linear Audio Vol 13 is out! Check out my Autoranger and SilentSwitcher
Old 1st February 2013, 10:22 AM   #19
just another
wintermute's Avatar
The answer to that is "it depends" when there are no tags it is where it is supposed to be. But when The tags are in place (at least the last one I did) it changed to N024!!!!
Tony.
Some of my photos
Old 1st February 2013, 10:35 AM   #20
Mooly's Avatar
Thanks for trying it Tony. Good to see its reproducible.
I'm a bit short on time today to try things on it but it does seem like a bug to me.
Phasing/soundtage anomaly Puffin Multi-Way 10 25th November 2012 09:50 PM
Redplating anomaly? dgta Tubes / Valves 18 29th October 2011 05:43 AM
JustMLS impedance anomaly Mos Fetish Multi-Way 0 6th March 2007 01:00 AM
LL1660S Anomaly arnoldc Tubes / Valves 17 3rd May 2006 01:00 AM
TAD TL-1102 response anomaly? Alidore Multi-Way 0 27th January 2004 04:54 AM
Copyright 1999-2017 diyAudio
