LTSpice tube models - Page 2 - diyAudio
Go Back   Home > Forums > Design & Build > Software Tools
Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
Old 6th December 2012, 04:10 PM   #11
cogsncogs's Avatar
The circuit hasn't been optimized to use a 6HM5. I just dropped it in to show that the 6HM5 model I posted works with no errors.
Old 17th December 2012, 03:32 PM   #12
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
Hi again. I found that this guy has made his own tube models using a point to point curve digitalizing, and has a great job and explained it. But I could't find why in some instances he used a "dummy resistor" in the text and how to estimate or calculate it and for what did he use it. Can somebody explain me this?
Best regards.
Osvaldo F. Zappacosta. Electronic Engineer UTN FRA from 2001.
Argentine Ham Radio LW1DSE since 1987.
Old 7th January 2013, 12:14 PM   #13
jazbo8's Avatar
Best regards.
You can send him a private message to see if he would answer your question. But looking at the model, I think the dummy resistors are used for either source or load impedance, most likely for SPICE calculation convergence purpose.
Old 9th January 2013, 03:24 AM   #14
tomlang is offline tomlang  United States
tomlang's Avatar
Did anyone get anything in the tubemodel_3.01_win.zip to work in LTSpice? I tried the 6ej7 pentode connection but it did not work.
Old 9th January 2013, 08:29 PM   #15
jazbo8's Avatar
Some don't work but most do, is my experience. I don't use LTSpice but SIMetrix, here is the Ia vs Vs plot for the 6EJ7 using Ayumi's model, matches up well with the datasheet:
Old 10th January 2013, 12:53 AM   #16
cogsncogs's Avatar
The 6EJ7 model as well as all of the others that I've tried in LTSpice seem to work OK. What error message are you getting? Have you changed all instances of ^ in the file to ** ?
Old 10th January 2013, 01:03 AM   #17
tomlang's Avatar
That worked, thanks! I read that earlier, just had trouble following the thread I guess. FYI, what do 3f4 and 3f5 refer to?
Old 24th October 2013, 08:11 AM   #18
coffin is offline coffin  Taiwan
coffin's Avatar
Hi
I am a newbie of TINA-TI. I'm trying to locate the spice model for EC86 / EC88 / Ec8010, but no result on the web. Please give a hand.
cheers
Coffin
Ignorance and self-centered are the epidemics of human.
Old 24th October 2013, 11:55 AM   #19
jazbo8's Avatar
See this thread.
Old 24th October 2013, 03:20 PM   #20
coffin's Avatar
Thanks a lot!
But when used the macro wizard to import EC86.mod, TINA-TI told me line 11 "V" is invalid function......
I'll try other models to see the result.
cheers
Coffin
GM70 and Other LTSpice Tube Models kevinkr Tubes / Valves 20 31st August 2012 10:45 AM
Symbol for tube diode in LTspice JoeAlders Software Tools 7 29th April 2012 02:49 PM
LtSpice - Russian tube models Svein_B Tubes / Valves 11 5th May 2010 02:55 AM
Ltspice and Valve models Melon Head Software Tools 3 18th October 2009 08:35 AM
Need help with tube models in LTSpice Bitrex Tubes / Valves 5 6th August 2009 07:28 PM
Copyright 1999-2017 diyAudio
