thermal pad on Eagle
2 Attachment(s)
hi,
attempted my first pcb design in Eagle.. i created a groundplane but Eagle doesn't connect components to groundplane, instead outputs empty borders around the holes.. attached pictures are what i got and settings of groundplane? what should i do to connect them? thanks in advance.. |
Did you rename the polygon to GND? Oh, I See, in the scematics, the GND is also named GND?
yes, sure..
oops.. no, i didn't draw the schematic in Eagle.. just placing the components to the board.. that is the problem?
I don't know how to solve this problem without using a scematic. Perhaps u could go for a star grounding ;)
i think, i can draw the schematic to solve the problem..
thanks for your helps Knorfski.. |
| All times are GMT. The time now is 05:58 PM. |
vBulletin Optimisation provided by
vB Optimise (Pro) -
vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
