Problem with simulation Load Sensing Circuit - diyAudio
Go Back   Home > Forums > Design & Build > Software Tools
Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
Old 4th November 2012, 02:51 PM   #1
Default Problem with simulation Load Sensing Circuit
Hello!
I try to simulate the load sensing circuit from Bob Cordells Book on Page 329 (see attachment).
So I added the parts in tina-ti and simulated it, but everytime the output voltage is about 7.4-7.6V
The voltage has to be much lower when less then 2,5 Ohms (R2) are connected.
The current at am1 is 10mA and the threshold is 2,5mV.
So now I need help, I don't get it... Maybe someone here knows what to do
Thanks,
Bernhard
File Type: png Bildschirmfoto 2012-11-04 um 15.46.04.png (84.2 KB, 22 views)
File Type: png Bildschirmfoto 2012-11-04 um 15.44.52.png (31.0 KB, 22 views)
Old 4th November 2012, 04:23 PM   #2
Default Solved!!
Problem is solved, I didn't connect the supply pins correctly
I thought pos. is on the upper and neg on the lower side of the symbol but that was wrong.
Thanks,
regards
Auto power-on signal sensing circuit Slanski62 Digital Source 13 15th August 2016 01:41 AM
Speaker Load Simulation LinuksGuru Multi-Way 22 9th July 2012 12:58 PM
Transistor circuit simulation rcollege Solid State 3 8th December 2010 08:06 PM
Current sensing circuit design help DC Dave Everything Else 5 21st April 2004 10:09 PM
Spice - speaker load simulation Kees Solid State 4 9th September 2003 12:08 AM
Copyright 1999-2017 diyAudio
