Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
Transmission Line Modelling Software
Old 15th January 2018, 05:27 PM   #851
matt scarlett is offline matt scarlett
I used it years ago when it first came out. Thought i might give it another try.
Old 16th January 2018, 12:44 AM   #852
perceval is offline perceval  Taiwan
perceval's Avatar
No, you are in "--/This PC/Downloads"
Move the line_installer folder to the place on the left called "Local Disk (C"
Old 16th January 2018, 04:35 AM   #853
Schreck is offline Schreck  United States
Matt,
Did you see post # 803?
Are you installing the files in the zip files attached to that post or the ones from the wayback machine?
-Schreck
Old 16th January 2018, 05:36 PM   #854
Originally Posted by Schreck View Post
Matt,
-Schreck
it won't let me save directly to C: It goes straight to 'Download' folder!
Old 16th January 2018, 06:15 PM   #855
GM is offline GM  United States
GM's Avatar
Copy/paste the folder to 'C' drive or just highlight it and 'drag' it there.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 16th January 2018, 06:35 PM   #856
I should have said; already tried it, and still the same result. I've tried to change the permissions, didn't work!
Old 16th January 2018, 06:39 PM   #857
shadders is offline shadders  United Kingdom
Are you logged in as administrator ?
Shadders.
Old 16th January 2018, 06:54 PM   #858
GM's Avatar
Ah! Oh well, I lucked up and installed mine right before his webpage went away, so no clue about dealing with this current work around beyond following the instructions and needing .NET.
GM
Old 16th January 2018, 07:04 PM   #859
Alternatively, create a directory on the c: drive - which is what you have to do anyway. Then move the zip file into this new directory and follow the instructions from there.
Shadders.
Old 16th January 2018, 07:33 PM   #860
Got it, thanks
Just for anyone else who might have the same problem (not being a techy ) I changed the 'Administrator' permission settings like so YouTube
dowloaded the file > moved it over (drag & drop/copy & paste) into C: > extracted zip file > Open tline_installer > then when you see options AF and TransmissionLine ... hit TransmissionLine (as per original instructions)
Thanks for all the help
Like i said, i used it before mainly for building subwoofer enclosures on the car audio side of things. However, even with the results, i sometimes felt that a just a little tweaking was needed beyond the graphs. Not to poo poo the software, anything but, its just sometimes what the graph was telling me, wasn't what i actually wanted. As for home audio speakers, I rarely if ever use damping, and if i do, its usual a nominal amount at the throat of the line. Just my preference. But I'm always learning
transmissionlinedesigns
Thanks again for all the help received.
Matt
Transmission Line Modelling SoftwareHide this!Advertise here!
TLwrx v 3.0 Transmission Line Software CarlosT Subwoofers 16 27th March 2008 04:25 PM
3 Way Crossover modelling Software? Grahame Multi-Way 3 13th May 2007 04:50 AM
Matlab-based triode modelling software Radames Tubes / Valves 1 16th September 2005 07:36 PM
3d modelling software greg_mcquaid Multi-Way 17 22nd May 2004 07:03 AM
