Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
Transmission Line Modelling Software
Old 22nd December 2017, 10:48 PM   #841
robotc is offline robotc  Australia
Hi
Moving the position of the driver down the line affects the various resonances in the line. A position 1/3 along the line is often used. You can see the effect if you open the enclosure window and drag the position of the speaker. The response will change as you do this. The aim is to minimize higher harmonic resonances by moving the driver and stuffing the line
It is not necessary to have a separate section for each folded section of the line unless the taper or cross section area changes. You can model it as one length.
Separate sections are useful if you plan to use different stuffing densities in different parts of the line
I am not sure about the depth variable. I have never used it. The cross section is the important value.
Hope this helps
Robert
Old 23rd December 2017, 12:17 AM   #842
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Originally Posted by shadders View Post
2. I plan to use an enclosure where the bass driver is at the top of the cabinet, and the transmission line goes down the back and has two folds before ported at the front bottom.
That sounds like an end loaded TL. It is really advantageous to offset the driver from the end of the line.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 23rd December 2017, 08:53 AM   #843
shadders is offline shadders  United Kingdom
Originally Posted by robotc View Post
Hi
Hope this helps
Robert
Hi Robert,
Thanks - this helps a lot. I was not sure if moving the driver down the line, whether it would treat the left hand (top) as open or closed.
So, my speaker will be a box (width and height of the driver, depth is the speaker depth which is the folds), and this box then leads into the transmission line.
Therefore, if i have 4 sections, the top box, and then the next are three folds/transmission line, is this the preferred simulation, or should i just accept some error and move the driver such that it is just within the top of the transmission line, using three sections ?
I can see how using different sections allows for different fills, but a kit i purchased has different cross sectional areas per section, so this may be better or worse than a continuous folded line.
Thanks and regards,
Shadders.
dave
Hi Dave,
Thanks - i will try this and see the results.
Shadders.
Old 23rd December 2017, 06:37 PM   #844
frugal-phile(tm)
planet10's Avatar
1/3 is only an approximation. If you look at Martin King’s Tables it gives appropriate offset ratios for different tapers.
The offset kills the 1st unwanted harmonic — the hardest one to attenuat with the fill — and allows for less damping and more of the fundemental getting thru yielding more bass reinforcement.
dave
Old 26th December 2017, 04:43 AM   #845
JZatopa is offline JZatopa  United States
Could someone tell me if I am using this software correctly? I am trying to model a JBL 2225H in a transmission line enclosure. It's hard for me to tell if Leonnard Audio is showing me what would be considered a good response or a poor one.
One thing I did notice was that if I use the wizard for a straght TL and then manually tapered it, I got a different response than if I used the wizard for a tapered TL.
Before I build anything I just want to know that I am modeling this properly.
Old 26th December 2017, 05:36 AM   #846
GM is offline GM  United States
GM's Avatar
Hmm, when I convert a straight TL to one that began as a tapered one, i.e. all dims are the same, they come out the same, so assume there's some sort of input error.
GM
edit: Re the sim, yes it looks fine, there will be some HF 'ripple' and to get rid of it and keep the LF gain requires designing with about a 4-6 dB peak at Fb to offset the extra damping required.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 2nd January 2018, 07:51 PM   #847
GM
GM
Hi GM, Thanks for the help. It was user input error but I figured out.
Is there any chance you could take a look at the sim I did on this link and tell me if that looks good or if I could model a better design? I tried to design in a 4-6db peak and then use dampening to flatten it out. Is that the best process?
Old 15th January 2018, 05:46 PM   #848
matt scarlett is offline matt scarlett
I can't open the program any help please?
Old 15th January 2018, 05:56 PM   #849
Did you follow the instructions :
the zip must be extracted to C:\tline_installer otherwise it won't work, i.e. you will have c:\tline_installer\TransmissionLine.application and then a subdir named AF which has the other files in it. Double click the application file and it should install normally without needing any webserver or external site.
Shadders.
Old 15th January 2018, 06:25 PM   #850
I've extracted the file and saved it to C:
tline_installer > AF > TransmissionLine (application Manifest)
Transmission Line Modelling SoftwareHide this!Advertise here!
TLwrx v 3.0 Transmission Line Software CarlosT Subwoofers 16 27th March 2008 05:25 PM
3 Way Crossover modelling Software? Grahame Multi-Way 3 13th May 2007 05:50 AM
Matlab-based triode modelling software Radames Tubes / Valves 1 16th September 2005 08:36 PM
3d modelling software greg_mcquaid Multi-Way 17 22nd May 2004 08:03 AM
