Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
Transmission Line Modelling Software
Old 5th November 2017, 12:07 AM   #821
3ll3d00d is offline 3ll3d00d  United Kingdom
3ll3d00d's Avatar
it appears to be in
Code:
%LOCALAPPDATA%\Apps\2.0\Data\Q8K89ZKR.2QY\RCVLQGO5.WVL\tran..tion_763839cbb13520ae_0003.0006_7afc777e67729b8e\Data\3.6.3.5
on my machine
Old 5th November 2017, 01:51 PM   #822
bnilsson is offline bnilsson
Thanks, I will take a look.
Old 13th November 2017, 02:37 PM   #823
perceval is offline perceval  Taiwan
perceval's Avatar
I am a little late to the party, sorry...
Thanks to Peter for providing the software in the first place, and 3ll3d00d to make it available now that leonardaudio's website is gone.
I'm trying to grasp how it works, so I made what I think is a copy of the TABAQ. I've seen the simulation from Bjorn, and built 2 pairs as well.
I split the first element into 2 parts so I could add different stuffing density, dense on top, nothing for the last 1/3 of the line. I then split the 2nd element and added a branch to it, which is I believe how to add a port. I put that on the bottom.
Here's what I get, and I'm not sure what to make of this. It follows the general cutoff frequency as in Bjorn's simulation, but here, I have this big initial first hump.
Anything I should've done differently?
File Type: png Screen Shot 2017-11-13 at 11.36.43 PM.png (25.6 KB, 345 views)
Old 13th November 2017, 04:12 PM   #824
GM is offline GM  United States
GM's Avatar
I don't see any value in the 'stuffing' field.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 13th November 2017, 09:33 PM   #825
robotc is offline robotc  Australia
What level of stuffing did you use? The original design uses 1lb/cubic foot. Did you use the heavy stuffing setting or set the stuffing density using the custom setting?
Robert
Old 13th November 2017, 11:01 PM   #826
markgolf is offline markgolf  United States
Robert I ended up using the custom stuffing setting and used .5/lbs per cu ft as the best result. Heavy stuffing is too much kills the low extension.1 pound isn't bad. Light stuffing doesn't hit the ripple at all
Mark
Old 14th November 2017, 03:00 AM   #827
perceval's Avatar
I guess my stuffing was too light.
So, the TABAQs were designed for about 70g of stuffing in the top part to just under the driver.
I figured about 40cm from top to a little under the driver. By 12.8cm deep and 10cm wide, that's 5120cm3.
70g/5120cm3 is about 0.014g/cm3.
If I change the first element's stuffing to 0.014g/cm3, this is what I get:
Old 14th November 2017, 09:31 PM   #828
That response looks way overdamped.What is the result if you use the value from Margolf, which is half of what you used?
What value of stuffing gives you the flattest response?
Robert
Old 15th November 2017, 01:41 AM   #829
zman01 is offline zman01  Bangladesh
Attached is a sim with Leonard Audio TL software for TABAQ with the TB W3-315SC driver.
Old 15th November 2017, 02:26 AM   #830
perceval's Avatar
Thanks all and zman for the test sim.
First, I now realized that even though I keyed in W3-315SC in Google, I got the specs for W3-315E instead. I replaced the specs for the right ones, and changed the stuffing to 0.2lb/ft3.
I got the same looking sim as yours. So, that's cool.
But... Bjorn said the stuffing should be 70 to 100g per TABAQ, so that comes up to 0.154 lb. or a stuffing density of 0.85lb/ft3.
Putting 0.85lb/ft3 makes for a way too much damped response looking like my previous example.
Now, I know the TABAQ works well with 70g stuffing, but according to this TL software, I shouldn't get the response down low I actually have.
So, where and how to overcome this discrepancy?
And btw, thanks for the help!
Transmission Line Modelling SoftwareHide this!Advertise here!
TLwrx v 3.0 Transmission Line Software CarlosT Subwoofers 16 27th March 2008 04:25 PM
3 Way Crossover modelling Software? Grahame Multi-Way 3 13th May 2007 04:50 AM
Matlab-based triode modelling software Radames Tubes / Valves 1 16th September 2005 07:36 PM
3d modelling software greg_mcquaid Multi-Way 17 22nd May 2004 07:03 AM
