Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
Transmission Line Modelling Software
Old 3rd April 2017, 07:45 PM   #761
Jerms is offline Jerms  United Kingdom
Hmmmm, Just did a little more playing with LA.... Please forget about the above post... It never happened.
On the plus side, I am happier and more confident with LA and HR.... On the downside, I need to remind myself to adopt a methodical and results backed approach rather than "youthful" or more likely "geriatric" enthusiasm.
J.
Old 22nd April 2017, 05:18 PM   #762
SpartanX58 is offline SpartanX58  Brazil
Why am I getting Net Framework exception errors in my computer everytime I try to run this program?
Old 22nd April 2017, 05:52 PM   #763
GM is offline GM  United States
GM's Avatar
Guessing it's because you don't have MS .NET installed: https://www.google.com/webhp?sourcei....net+framework
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 22nd April 2017, 06:00 PM   #764
GM's Avatar
Definitely! FWIW, maybe these tutorials will give you a better understanding of the physics plus need to understand that with a vented TL alignment it's a closed pipe [1/4 WL] tuned with an open pipe [1/2 WL] resonator: Resonances of open air columns
GM
Old 28th April 2017, 07:41 AM   #765
GM
I do have it, but it is not working on this Leonard Audio.
Old 28th April 2017, 03:28 PM   #766
Reinstalled the program and got rid of the problem.
Old 28th April 2017, 04:02 PM   #767
GM's Avatar
Cool, glad it solved the problem because not being particularly computer savvy, this, and 'reboot the computer' is always what I'm told when I ask similar Qs.
GM
Old 31st July 2017, 10:09 PM   #768
opc is offline opc  Canada
opc's Avatar
Hi Guys,
Does anyone know the status of the Leonard Audio website?
All links have returned a DNS error for the past 5 days... looks like it has either been taken down or there are some other issues. I recently re-formatted my PC and would like to re-install this.
Can anyone here provide the executable installer in ZIP or RAR format? Should be small enough to attach.
Owen
Old 12th August 2017, 03:01 PM   #769
wae is offline wae  Netherlands
Default Leonard Audio site
Hi Owen,
Sure looks like is not in the air.
I do have the last beta, but is it NOT mine. I don't know what's going on.
Would it be fair to publish the executable, not being the owner?
Is there someone who can shed a light on Leonard Audio?
MUCH appreciated.
Frans
"If i ain't broken, DON'T fix it"
Old 12th August 2017, 06:18 PM   #770
GM's Avatar
FWIW, we went through this the other day and only got as far as the setup file: Full Range Build, 12" driver...
From dim memory this is freely available from day one that was partially developed or at least had significant input, from some folks here, so personally feel like I could at least email it and if I had a place to post it without all the associated spam.
BTW, where is the program? Don't see it in its folder or in the various Win 7 pro files
GM
Transmission Line Modelling SoftwareHide this!Advertise here!
TLwrx v 3.0 Transmission Line Software CarlosT Subwoofers 16 27th March 2008 04:25 PM
3 Way Crossover modelling Software? Grahame Multi-Way 3 13th May 2007 04:50 AM
Matlab-based triode modelling software Radames Tubes / Valves 1 16th September 2005 07:36 PM
3d modelling software greg_mcquaid Multi-Way 17 22nd May 2004 07:03 AM
