Transmission Line Modelling Software - Page 58 - diyAudio
Go Back   Home > Forums > Design & Build > Software Tools
Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
Old 24th February 2014, 11:53 PM   #571
GM is offline GM  United States
GM's Avatar
Close enough for me!
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 25th February 2014, 02:36 AM   #572
Greebster's Avatar
What kind of power handling are we talking about here? Even with only 3 watts this is getting into the 2mm Xmax range on a driver only rated for 0.5mm.
Old 25th February 2014, 04:34 AM   #573
GM's Avatar
Most drivers have a rising rate suspension, so Xmech [Xlim] can be considerably more than its Xmax, though no clue about much this one will 'stretch' before it takes high power to actually drive it to bottoming out. VCs use to overheat first, but the high temp glues available today may allow them to handle 2-3x their rated power before popping. Only one way to know for sure.........
GM
Old 25th February 2014, 12:34 PM   #574
Greebster's Avatar
GM
Heh so true, keep a close eye while turning it up. Wife thought I was nuts when asking her to measure the displacement while I depressed the cone to measure unspecified Xlim. Was happy it was at least double Xmax (6mm), gets her involved with the process
Yes could have made a jig, but why miss out on all the family fun
I am soooo sure she likes to be involved!
Old 25th February 2014, 02:33 PM   #575
GM's Avatar
I've been fortunate in that I've never had any of the SAF/WAF issues others have/had to endure and all helped me when asked regardless of the project, with only one setting any conditions. She made it plain from the get-go that she'd help with anything that didn't put her meticulously maintained nails in harm's way.
Indeed, I relied heavily on their generally keener hearing to 'voice' driver tweaks and finished speakers and I assume why the speakers I built for others were so well received by their 'better halfs'.
GM
Old 25th August 2014, 06:46 AM   #576
blakkshepeaudio's Avatar
Just a quick check if there are any updates in the works for this excellent program.
Old 11th September 2014, 04:31 PM   #577
schmeet is offline schmeet  United Kingdom
schmeet's Avatar
Hi blakkshepaudio. There aren't any updates imminent but I have do have a bug/update list that that I intend on working through when there is time available. If you have any requests or comments then I'd be happy to add them to the list...
Old 12th September 2014, 08:40 AM   #578
Thanks for the response schmeet !
Love this program.....
Old 13th September 2014, 06:45 AM   #579
schmeet's Avatar
I uploaded a small update last night which fixes a few bugs, nothing major.
Old 14th September 2014, 03:28 AM   #580
Thanks again.
However, program no longer installs or runs
I can send you the log file If you like.
blakktieball
TLwrx v 3.0 Transmission Line Software CarlosT Subwoofers 16 27th March 2008 04:25 PM
3 Way Crossover modelling Software? Grahame Multi-Way 3 13th May 2007 04:50 AM
Matlab-based triode modelling software Radames Tubes / Valves 1 16th September 2005 07:36 PM
3d modelling software greg_mcquaid Multi-Way 17 22nd May 2004 07:03 AM
Copyright 1999-2017 diyAudio
