Transmission Line Modelling Software - Page 49 - diyAudio
Go Back   Home > Forums > Design & Build > Software Tools
Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
Old 12th November 2013, 03:44 PM   #481
Greebster's Avatar
Say after several hundred tweaks to a model it will blank out the total volume. This doesn't appear to be caused by anything specific that triggers the error that I have noticed. Will try to replicate.
If I save the tlp and restart, then reload it is fine.
Any update to the offset in the curves <~60-80hz being displayed lower and 200Hz up being too high?
Old 12th November 2013, 04:16 PM   #482
schmeet is offline schmeet  United Kingdom
schmeet's Avatar
I'll see if I can find a reason for this, but it does seem very random!
This is to do with the stuffing model, I am currently looking at alternatives and will update if I settle on one...
Old 13th November 2013, 03:09 AM   #483
LineSource's Avatar
Your latest release works without issues on Windows Vista64. I enjoy using your program and appreciate your efforts.
Could you add one decimal point of precision on the freq and SPL displayed on the bottom left corner in the Sound Pressure Level graph? Not a critical issue.
XX.x Hz
Value: [System = XX.x ]
Do you have any ideas on how to model the "resistive nature" and "resonant nature" of several deep-but-narrow slot port as used on Onken style woofer cabinets? AkaBak is the current best simulator for this level of port air flow detail. Your models may not be suitable, but I'd appreciate your thoughts.
Old 13th November 2013, 08:37 AM   #484
schmeet's Avatar
Thanks, that's good to know
Done. I'll release the update later today I think.
Erm.. This should just model in the normal way. If you have details of a design and accurate sims/measurements to compare I'll happily look into it.
Old 19th November 2013, 03:24 AM   #485
Greebster's Avatar
OK this time when dragging a section out the "Volume" changed to "NaN" and no longer responds.
Also discovered when adding a new branch to the baseline model it's effects are not calculated now. Odd
Old 19th November 2013, 09:00 AM   #486
schmeet's Avatar
Ok thanks. Still looking into this. Its hard to find the bug as it doesn't do it for me...
Do you just mean the volume isn't calculated. Or that the model (freq response) doesn't change at all?
Edit: I think I can see the problem here. It happens when you put a branch on the first element of the model. Is that correct?
Old 19th November 2013, 12:21 PM   #487
Greebster's Avatar
That's what was causing me to hold back reporting this, it's that blasted where, when, what, how...
Correct. The added branch doesn't change the results regardless of volume, length or dampening.
Old 19th November 2013, 01:24 PM   #488
schmeet's Avatar
It's useful reporting these things. Just hard to find sometimes! I'll hunt it down!
I know how to fix that branch issue, just need to get round to it. In the meanwhile, you don't actually need to use a branch on the first element as it is the same as moving the driver down the first element. Nevertheless I will fix it soon.
Old 25th November 2013, 06:56 PM   #489
schmeet's Avatar
New update has just been uploaded:
- Added a decimal place to the graph cursor readout as requested.
- Fixed the bug where the branch on the very first element would be ignored.
- Changed the stuffing model to be more accurate (More at higher frequencies, less at lower).
Transmission Line v3.6.3.2 | Leonard Audio
Old 28th November 2013, 06:25 PM   #490
Thank you for the update, is there a way of downloading the software directly? My wifi isn't working and I tried to download the .exe through my phone and transfer it over to my computer but the installer wants to connect to the Internet
TLwrx v 3.0 Transmission Line Software CarlosT Subwoofers 16 27th March 2008 04:25 PM
3 Way Crossover modelling Software? Grahame Multi-Way 3 13th May 2007 04:50 AM
Matlab-based triode modelling software Radames Tubes / Valves 1 16th September 2005 07:36 PM
3d modelling software greg_mcquaid Multi-Way 17 22nd May 2004 07:03 AM
Copyright 1999-2017 diyAudio
