Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
Transmission Line Modelling Software
Old 28th September 2012, 06:04 AM   #31
schmeet is offline schmeet  United Kingdom
schmeet's Avatar
Originally Posted by mrkennyk View Post
I just downloaded the latest version and I can not enter Qts, Vas, etc. They are grayed out. What went wrong?
At the minute , you enter the other parameters and these are then calculated. I think I will try and change this so you can enter the more 'conventional' parameters and the others are calculated. Haven't decided quite how it will work yet though..
Old 28th September 2012, 06:05 AM   #32
NEO Dan is offline NEO Dan  United States
NEO Dan's Avatar
Originally Posted by schmeet View Post
Pete,
In the Amplifier window, you set the input power (in watts). It then uses the Re of the driver to calculate the input voltage sqrt(Re x Power).
Oh, now that will throw you out of whack with most other models out there. I recommend input boxes for Voltage, Nominal Impedance, & Power, enter any two.
Dan
Old 28th September 2012, 06:06 AM   #33
PB2 is offline PB2  United States
PB2's Avatar
Pete,
I see, it would be very helpful to have the computed RMS input voltage displayed somewhere or both as I said earlier. Most plot for 2.83 Vrms in, just to show the
standard voltage sensitivity, but power is fine also.
Old 28th September 2012, 07:51 AM   #34
schmeet's Avatar
Thanks for the suggestions guys.
Version 2.3 has just been uploaded (as before you can update from the about window).
I have added units to the enclosure window, as well as the calculated internal volume.
I have also adjusted the driver t/s inputs so you enter the more conventional inputs. i will try and do an option to change between which set of parameters you enter.
I will also give you the option of voltage or power when I get round to it. Do you think it is worth giving another option for impedance, even though this is specified in the T/S parameters?
Got to do some real work now, I'll check back in a bit!
Pete
Old 28th September 2012, 08:56 AM   #35
NEO Dan's Avatar
Conventionally speaking power is calculated based on the nominal impedance of the system as opposed to Re of the voice coil.
Thanks for your hard work Pete!
Dan
Old 28th September 2012, 09:49 AM   #36
schmeet's Avatar
Yeah, that does make sense. i guess Znom should be a T/S parameter to enter at the driver input screen
Old 28th September 2012, 11:35 AM   #37
schmeet's Avatar
Version 2.4 just uploaded.
Added Znom as a driver parameter.
Amplifier window has changed to allow entry of either Voltage or Power (using Znom).
Old 28th September 2012, 12:16 PM   #38
PB2's Avatar
Actually, Pete if I am remembering correctly T&S did use Re for calculating input Pe when displaying power limited output. It is just a rough worst case approximation, but I think it is better than using Znom which can be anything. Znom is not a T&S parameter, don't think I've seen it on a data sheet but if it is there it is a marketing parameter.
T&S Papers online:
http://www.readresearch.co.uk/articles.php
Old 28th September 2012, 12:46 PM   #39
schmeet's Avatar
Hmm.
Yeah I got my formulas from their papers, which is why i used Re in the first place. Isn't Znom more of an average resistance as the resistance changes with frequency?
Looking at MJKs stuff, he uses Re too. Maybe i should go back to that...
Old 28th September 2012, 01:24 PM   #40
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
Hmm.
Suggestion. Copy this approach:
Hornresp
b
Transmission Line Modelling SoftwareHide this!Advertise here!
TLwrx v 3.0 Transmission Line Software CarlosT Subwoofers 16 27th March 2008 04:25 PM
3 Way Crossover modelling Software? Grahame Multi-Way 3 13th May 2007 04:50 AM
Matlab-based triode modelling software Radames Tubes / Valves 1 16th September 2005 07:36 PM
3d modelling software greg_mcquaid Multi-Way 17 22nd May 2004 07:03 AM
