Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
Transmission Line Modelling Software
Old 20th December 2012, 02:42 PM   #381
wmb is offline wmb  United States
Oh, different WinISD file formats. The .dri format starts with the line "[Main]" and has Vas in liters. .wdr starts with "[Driver]" and has Vas in m^3.
Old 20th December 2012, 02:48 PM   #382
schmeet is offline schmeet  United Kingdom
schmeet's Avatar
oh, I haven't come across .dri yet...
I'll have to update the code to recognise them as well then.
Old 20th December 2012, 09:26 PM   #383
Keriwena is offline Keriwena  United States
The .dri files are the ones you enter yourself.
Old 20th December 2012, 11:52 PM   #384
Mosquito is offline Mosquito  Argentina
Mosquito's Avatar
Gents I have had no problems importing the WinIsd drivers database to Leonard TL , and then in opening any driver in the list...
edit: Ok I see now the problem was solved...
"It is less serious than if worst"
Old 21st December 2012, 04:11 PM   #385
schmeet's Avatar
Just uploaded Version 3.6.1.10
I have made the status bar give both frequency and value (i.e. SPL) when you click on the graphs.
Right clicking on a graph gives you options to copy the graph image to the clipboard or save it as a picture file.
In the geometry editor, pressing the enter key when editing the form will update the model.
Old 21st December 2012, 05:58 PM   #386
geraldfryjr is offline geraldfryjr  United States
Cool Thank You for this !!!
" I have made the status bar give both frequency and value (i.e. SPL) when you click on the graphs."
jer
Old 21st December 2012, 05:58 PM   #387
Using 3.6.1.10, I have Length Units set to Inch, Precision 1. In the Element display, I have the Length unit set to "in". When I adjust the element length with the mouse, the status display at the bottom of the window lists the unit as in, but the numerical value is in meters.
For example, if the element is currently 15 inches long, during the mouse drag, the status bar says "0.381 in" (0.381 meters is 15 inches).
Old 21st December 2012, 06:02 PM   #388
The "Enter causes update" feature does not work in the "Depth" field of the "Model Info" sub-panel. (I mean that it does not change the geometry display; that change is deferred until you move to a different field.)
Old 21st December 2012, 06:16 PM   #389
I split a parallel-sided element (taper ratio 1). The dividing line became orange as expected. I then changed the stuffing for one of the elements, without changing anything else, and the orange line changed to dashed red. I would not expect that different stuffing densities would prevent adjustment of a split.
Old 21st December 2012, 10:12 PM   #390
schmeet's Avatar
Wmb, cheers for those points. They are all things i overlooked and can easily fix for the next release..
Transmission Line Modelling SoftwareHide this!Advertise here!
TLwrx v 3.0 Transmission Line Software CarlosT Subwoofers 16 27th March 2008 04:25 PM
3 Way Crossover modelling Software? Grahame Multi-Way 3 13th May 2007 04:50 AM
Matlab-based triode modelling software Radames Tubes / Valves 1 16th September 2005 07:36 PM
3d modelling software greg_mcquaid Multi-Way 17 22nd May 2004 07:03 AM
