Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
Transmission Line Modelling Software
Old 13th December 2012, 01:47 AM   #311
Keriwena is offline Keriwena  United States
Really good suggestions, wmb.
Old 13th December 2012, 06:21 AM   #312
Thawach is offline Thawach  Thailand
Thawach's Avatar
schmeet no have dl option?
Old 13th December 2012, 06:23 AM   #313
schmeet is offline schmeet  United Kingdom
schmeet's Avatar
Wmb, thanks for the suggestions. I'll see what I can do....
Twhatch, sorry but what?
Old 13th December 2012, 06:50 AM   #314
Thawach's Avatar
hi schmeet pipe outlet different position(rear or front)
Old 13th December 2012, 09:09 AM   #315
schmeet's Avatar
You can get offset drivers and/or offset ports by using branches. I don't have time right now to fully explain so I will just leave you with a Project save file.
- Remove the .txt so you have MLTQWT.tlp
- Double-click the file or open it in the app.
- Open the Geometry Display window and see how the offset driver and port have been made.
File Type: txt MLTQWT.tlp.txt (905 Bytes, 43 views)
Old 13th December 2012, 01:28 PM   #316
schmeet's Avatar
With the above file. Please be aware that this is a file for the latest version of the programme and cannot be opened by previous versions.
I have tried to make it so new versions can open older save files, but it is impossible to do it the other way round....
Old 13th December 2012, 02:14 PM   #317
schmeet's Avatar
Today's updates: [Thanks to wmb for the suggestions]
- Selecting an element no-longer auto-updates the model.
- When you are changing the start or end area and the adjoining element has the same area then you can hold down Ctrl it will adjust both areas simultaneously.
- Whenever a Length Handle and an Angle handle are on top of one another then the Length handle now takes priority. (Note: if you zoom in or out then you they should both become visible as the angle handle size has no bearing on zoom)
Wmb, you mentioned that the scroll wheel sometimes changes taper type rather than zooming. this will be because you have focused on the taper type box. You just need to click back on the graph..
Old 13th December 2012, 02:33 PM   #318
Personally, I miss being able to use the arrow keys to fix typos in the input areas.
Minor: "Degree" is cut off in the Geometry Display and the Start Area is shorter than the other entry windows.
Old 13th December 2012, 02:57 PM   #319
schmeet's Avatar
Keri,
I didn't realise that the arrow keys didn't work on text boxes. I have quickly uploaded another update which has fixed (Along with the other two issues you noted)
Thanks,
Pete
Edit: and that's me done for today else I'll get square eyes!
Old 13th December 2012, 06:37 PM   #320
wmb is offline wmb  United States
Nice!
More nits, for when you have had some rest :-)
Ctrl-to-simultaneously-adjust doesn't work if one element is a branch. The use case is driver offset, where you typically want the same areas at the join.
Oh, and how about this: When a new element or branch is created, automatically select it.
And when a new branch is created, make its its initial area the same as its parent's area, instead of fixed at 500 cm2, and rotate it e.g. 90 degrees relative to its parent, to make it clear that it's a branch.
Transmission Line Modelling SoftwareHide this!Advertise here!
TLwrx v 3.0 Transmission Line Software CarlosT Subwoofers 16 27th March 2008 04:25 PM
3 Way Crossover modelling Software? Grahame Multi-Way 3 13th May 2007 04:50 AM
Matlab-based triode modelling software Radames Tubes / Valves 1 16th September 2005 07:36 PM
3d modelling software greg_mcquaid Multi-Way 17 22nd May 2004 07:03 AM
