Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
Transmission Line Modelling Software
Old 12th December 2012, 03:05 PM   #301
schmeet is offline schmeet  United Kingdom
schmeet's Avatar
Originally Posted by JacquesToo View Post
I'm still struggling to install any version. Any solutions to this yet? Running XP, if that makes a difference. 1st attempt installed without hitch..
As Keri has said. This is normally an issue with people not having the correct .Net Framework. However when you click install, it should also install the pre-requisite elements too.
Are you installing by clicking the install button on the website?
What is going wrong? Do you get error messages?
Old 12th December 2012, 03:12 PM   #302
schmeet's Avatar
Version 3.6.1.0 has just been uploaded.
I have changed the zoom to the scroll wheel. Pan is still assigned to the middle mouse button but you can now change this by going to the Settings Window and the Mouse Tab
Old 12th December 2012, 03:21 PM   #303
JacquesToo is offline JacquesToo  South Africa
JacquesToo's Avatar
Post .NET
Schmeet, I do.
(It worked the first time, identical environment.)
Stumped. Does it use any exotic processes? I turn off Security Centre, for example. And Windows Firewall.
Old 12th December 2012, 03:53 PM   #304
schmeet's Avatar
The only thing that has changed significantly recently is that you now require windows installer 4.5 rather than 3.5
Though this should get installed when you click on Install if you don't already have it.
You can check your version of Windows Installer by opening up the command prompt (Start -> Run -> cmd) and typing msiexec/?
Let me know...
Old 12th December 2012, 04:21 PM   #305
JacquesToo's Avatar
Ahem..
v 3.01
I'll update and let you know..
Old 12th December 2012, 05:25 PM   #306
schmeet's Avatar
Just uploaded another update [3.6.1.1]
Updates to Geometry Display...
Added Reverse element option to Right Click Menu
Added multiple Paste Options - Paste After, Paste Before and Paste as Branch
I also made it only paste the actual element and not all branches as before, i think this is more usable this way.
And the last update is one I think will help significantly. When you resize an element with the Length Tool 'Handle', if you hold CTRL then it will alter the Start Area of the element in order to maintain the same Flare Constant. If you hold SHIFT then it will alter the End Area of the element to maintain the same Flare Constant.
I have done this in an attempt to make it easier to setup offset drivers...
Let me know what you think.
Old 12th December 2012, 09:19 PM   #307
schmeet's Avatar
I've been busy tonight.... :P
Another update [3.6.1.2]
Added more shortcuts keys to the Geometry Display
- Ctrl+C = Copy
- Ctrl+V = Paste
- Del = Delete
- R = Reverse
- O = Open End
- C = Closed End
- S = Split Element
+/- = Zoom in and out
Up/Down/Left/Right = Pan
I have changed the element split so that it just does a 0.5 split straight away. However, I have added some functionality so that you can drag the split by clicking on the first element and clicking and dragging the orange line (The mouse icon will turn to a split divider).
I have also updated the open/save programming so to try and avoid cultural inconsistencies with regard to commas and dots and decimal characters. This should enable us to share project files more easily.
Thanks,
Pete
Old 12th December 2012, 10:35 PM   #308
Mosquito is offline Mosquito  Argentina
Mosquito's Avatar
Default you do your magic!
Hi!
I've just updated to the last version, and now everything works fine, the old file project run again etc...
Ah! and the mouse wheel act fine as middle button, (you click the wheel over the displayed geometry and it drag like a John Deere)
"It is less serious than if worst"
Old 12th December 2012, 11:06 PM   #309
schmeet's Avatar
Great. Glad to hear it.
Old 13th December 2012, 02:27 AM   #310
wmb is offline wmb  United States
Thanks for the program. I spent hours yesterday exploring it, and as a result, I redesigned some ported towers I'm building for a friend.
I have some UI suggestions:
1) Update when the Enter key is typed in an input field, according to common usage.
2) Don't auto-update when merely selecting an element - wait for an actual change. Auto-update-on-select impacts the UI responsiveness, and also has some bad interactions with drag-select. I have experienced several unhandled exceptions as a result of mouse movement during auto-update when the drag selection box was open.
3) A "would be nice": when changing the start area or end area and the adjoining element has the same area, change both simultaneously. You could make it contingent on both elements having the same angle, so if someone wanted to decouple the areas, they could just tilt one.
4) When the length is such that the length control overlays the angle control, it becomes impossible to select the length control. Length adjustment is more common than angle adjustment, so it should have priority. Or you could offset one of the controls away from the centerline so they don't overlay.
5) When the angle is more vertical than horizontal, exchange the left-right and up-down double-arrow cursors.
6) On startup, open the last-saved project instead of the default one.
7) The mouse scroll wheel sometimes scrolls through the Taper Type choices instead of changing the zoom factor. Unfortunately I can't reproduce this problem at will, so I can't give you the precise scenario that causes it. Something to keep an eye out for ...
8) "Would be nice" to import WinISD driver data...
9) "Would be nice" to have an addition model length (total) that excludes branches. Thus one could put ports on branches, and see the total length of the enclosure proper.
Thanks for a great program. I'll donate if you set up a PayPal thing.
And since everybody likes speaker photos, here are some omnis I built for a church ... (unrelated to TL)
Transmission Line Modelling SoftwareHide this!Advertise here!
TLwrx v 3.0 Transmission Line Software CarlosT Subwoofers 16 27th March 2008 05:25 PM
3 Way Crossover modelling Software? Grahame Multi-Way 3 13th May 2007 05:50 AM
Matlab-based triode modelling software Radames Tubes / Valves 1 16th September 2005 08:36 PM
3d modelling software greg_mcquaid Multi-Way 17 22nd May 2004 08:03 AM
