Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
Transmission Line Modelling Software
Old 27th September 2012, 08:03 PM   #21
schmeet is offline schmeet  United Kingdom
schmeet's Avatar
Thanks for your comments Pete. Yes I did use VB.net to write the app.
I calculate the acoustic impedance of each element of the pipe and then add them all together in series. If you want to know in more detail I can, but maybe this thread isn't the best place.
Thanks for the suggestion about enclosure volume. I will also update the t/sninput as per your comment.
Pete
Old 27th September 2012, 08:11 PM   #22
NEO Dan is offline NEO Dan  United States
NEO Dan's Avatar
Hi Pete,
Please don't abandon the parameter set you have now, but please expand with the ability to cross calculate.
I too have some interest in the programming if it is open to discussion somewhere.
Dan
Old 27th September 2012, 09:32 PM   #23
mrkennyk is offline mrkennyk  United States
I just downloaded the latest version and I can not enter Qts, Vas, etc. They are grayed out. What went wrong?
Old 28th September 2012, 12:56 AM   #24
PB2 is offline PB2  United States
PB2's Avatar
Originally Posted by NEO Dan View Post
Hi Pete,
If you really must have the much more unconventional parameter input I'd say use a switch check box to select the format rather than trying to guess at which one is the input value. Something like a check box for standard T&S vs. mechanical parameters. I think it would just confuse things otherwise.
Pete you might also put a comment on the SPL graphs for the power input assumed, and really isn't it constant voltage so not really power? Giving power that is really constant voltage means we need to know the assumed load resistance or do you always use an 8 ohm reference? You might just give both, something like 100W - 28.3Vrms.
Once again Pete, thank you so much for this excellent tool!
Old 28th September 2012, 01:16 AM   #25
PB2's Avatar
Pete
I know how to do this since I had to figure it out the first time around where I had to think long and hard about it - it took me a while to figure this out. I spent many long hours reading the classic papers.
Here are the steps for the case with no driver offset (driver is at the start of the line) in case anyone is interested; Pete please let me know if you agree:
1. Calculate the radiation impedance of the port
2. Load the last section with the above impedance and calculate the input impedance.
3. Load the next closer section with that input impedance as the termination impedance.
4. Continue until you get to the line input impedance loading the driver.
5. Compute the volume velocity vs. frequency for the driver loaded by the first section input impedance.
6. You now have the volume velocity of the speaker cone.
7. Compute the first section volume velocity transfer function from input to output as loaded by the next section.
8. Repeat and compute all section transfer functions as loaded by the next section and finally the port.
7. Take the negative (back side of cone) of the cone volume velocity and use it as the driving source for the first section of line to compute the first section output volume velocity.
8. Repeat using each sections volume velocity transfer function until you get to the port output.
9. Plot cone and port output and vector sum them to get the total system output converting volume velocity to SPL at the assumed distance.
Old 28th September 2012, 01:29 AM   #26
geraldfryjr is offline geraldfryjr  United States
This a great program !!
I have tried to use the other ones for TL's but I just haven't been persistent in understanding how to use them.
This one helps me to better understand changes that effect the results as I am just a Noob when it comes to TL's.
Thank you!!!
jer
Old 28th September 2012, 03:16 AM   #27
PB2's Avatar
Yes, the learning curve is about 10 minutes, probably less if you know TLs.
Amazingly well thought out!
Old 28th September 2012, 03:53 AM   #28
NEO Dan's Avatar
Gee ,
I do believe Pete has used the "conventional" data needed for the mathematical model. One must consider what's going on behind the curtain...
Dan
Old 28th September 2012, 03:58 AM   #29
NEO Dan's Avatar
I would love to remake it for android. i have just downloaded the software development kit but it will take a while for me to get my head around it.
I wont be doing anything for macs in the near future. Although i may remake it as a webapp, so everything could use it then...
Looks like Java will get you on every platform now...
Dan
Old 28th September 2012, 06:02 AM   #30
schmeet's Avatar
Pete,
In the Amplifier window, you set the input power (in watts). It then uses the Re of the driver to calculate the input voltage sqrt(Re x Power).
Transmission Line Modelling SoftwareHide this!Advertise here!
TLwrx v 3.0 Transmission Line Software CarlosT Subwoofers 16 27th March 2008 04:25 PM
3 Way Crossover modelling Software? Grahame Multi-Way 3 13th May 2007 04:50 AM
Matlab-based triode modelling software Radames Tubes / Valves 1 16th September 2005 07:36 PM
3d modelling software greg_mcquaid Multi-Way 17 22nd May 2004 07:03 AM
