Go Back   Home > Forums > Design & Build > Software Tools
Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
Old 8th December 2012, 03:53 PM   #281
buzzforb's Avatar
I have found some dissimilarities in the two programs, but trying to make sure it is not operator error. At this time my assumption is the latter.
|F6 Kit/Trasnformer GB Sign up sheet Closed,|Primrose GB Sign Up sheetClick Here
...Shape the sound , Man!
Old 8th December 2012, 06:08 PM   #282
There can be differences in the way damping is handled. To be fair, set the Stuffing in TL.app to 'None' for all elements, and, for instance, in WinISD set the Ql to '20'.
Old 9th December 2012, 12:59 AM   #283
Mosquito's Avatar
Default DBR
Philips 9710 Double Bass Reflex in Series,
not optimized, but doesn't matter, it can be done!
File Type: txt Philips DBR.tlp.txt (488 Bytes, 26 views)
I know how to walk over grapes
Old 10th December 2012, 09:25 AM   #284
schmeet is offline schmeet  United Kingdom
I have uploaded an update this morning.
There aren't any major changes just a couple of GUI things. I have made the element info section a bit smaller so that you can make the Grometry Display window thinner. I have had a comment from a user that they struggle to have the plot and display windows visible at the same time.
The auto-update checkbox is now a button on the display window toolbar.
The element info section maintains its size better during window re-sizing. The element info collapse button maintains its position in the middle of the window (vertically) during window re-sizing.
Geometry Display window now remembers its size and model position/zoom.
Transmission Line Modelling Software
Old 10th December 2012, 11:40 AM   #285
There were some bugs in the last update (3.5.2.6) that didn't show up in my debugging build.
I just updated again (3.5.2.7) and they should be fixed now.
Old 11th December 2012, 01:06 PM   #286
Fairly big update today! [3.6.0.0]
- Added Boundary option to Element Info (in Geometry Display Window)
- Added keyboard shortcuts to Geometry Display. (o = Open End, c = Closed End, DEL = Delete)
- In Geometry Display, changed move to middle mouse button
- Added 'Selection Rectangle' to left mouse button
- Changed tlp save file format (more readable)
- Added functionality for Rear + Front enclosures. This should enable you to model Rear or Front loaded horns or Band-pass boxes. I have checked this with one known enclosure and it seems to work fine, but let me know if you have any problems.
Enjoy...
Pete
Old 11th December 2012, 02:45 PM   #287
My first problem is, I can't move the display around - I don't have a middle mouse button.
How about making the 'zoom' work with a scroll wheel?
Old 11th December 2012, 02:56 PM   #288
You don't have a middle mouse button, but you do have a scroll wheel?
Hmm.. I suppose Ctrl + Left mouse button could work....
Old 11th December 2012, 05:50 PM   #289
Mosquito's Avatar
Default ?!?
Every saved work is lost with the new version . Saved geometries will no longer open. Starting the learning curve from scratch, once again...
A bit of help to understand the new front/rear concepts?
Cheers
J
Old 11th December 2012, 05:51 PM   #290
Mosquito's Avatar
Me too..
TLwrx v 3.0 Transmission Line Software CarlosT Subwoofers 16 27th March 2008 04:25 PM
3 Way Crossover modelling Software? Grahame Multi-Way 3 13th May 2007 04:50 AM
Matlab-based triode modelling software Radames Tubes / Valves 1 16th September 2005 07:36 PM
3d modelling software greg_mcquaid Multi-Way 17 22nd May 2004 07:03 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
