Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
Transmission Line Modelling Software
Old 6th November 2012, 03:39 PM   #191
schmeet is offline schmeet  United Kingdom
schmeet's Avatar
Thanks for those points Keriwana. Some very helpful and valid stuff there. If you could email over the details of the error message that would be great.
peter@leonardaudio.co.uk
I will look at the other points individually at a later stage. Busy with an update at the moment, which may actually help with a couple of your points...
Old 6th November 2012, 05:35 PM   #192
Keriwena is offline Keriwena  United States
Sent, and thanks.
Again, I urge everyone to share your opinions, comments, bugs and wishes. Programmers need feedback. We're always "too close to the painting", because we know what goes on inside. It always meets our expectations, but what's important is everyone else's expectations, because that's who we're writing it for.
So please, help Peter out. I think this program has great promise.
Old 6th November 2012, 05:38 PM   #193
What size icons do you need? 16x16?
Old 6th November 2012, 07:04 PM   #194
schmeet's Avatar
Thanks for the email, I'll look into.
Yes 16 x 16 is correct.
I have an update for Basic and Advanced geometry modes. I'll upload tomorrow as I need to go out now. I would appreciate your thoughts on whether it is worthwhile having this though and how it could be improved.
The issue with it at the moment is that when you go from Advanced to Basic, you will lose all of your branches.. Anyway, you'll see tomorrow...
Old 7th November 2012, 11:54 AM   #195
schmeet's Avatar
Update has been uploaded.
Originally Posted by Keriwena View Post
It would be handy if the 'total length' units matched the 'length' units.
You can change the units of Total Length too. I could link them, but I don't think it's necessary...
Can the program remember measurement unit settings in the .tlp file?
Yes, and they now are
For the red lines in the geometry window, could you use a different colour for 'open'?
Open ports do not have the dotted lines at the end. This should enable you to distinguish them. Is that what you meant?
Is it possible to get a readout of the angle of the sides for aligning multiple elements? Once something is 'split' it's difficult to alter the cross section.
I'm working on this. Not completely sure how best to alter the areas of segments where you want to maintain the taper.
Speaking of 'split', while it's very helpful for applying different amounts of damping to various portions of the line, if there was another version that added an element "above" the '0' element, that would make placing the driver part-way down the line easier. I guess that would be a split that adds a branch.
The new 'Basic Mode' should enable you to easily do off-set drivers. Although its ideal yet, its a work in progress...
Can the main window remember its position?
Yes, it now does.
Could you add 5's on the frequency scale?
I'm not sure what you mean by this?
Pete
Old 7th November 2012, 08:05 PM   #196
Cool. Looks good at first glance.
Duh! I missed that. You must have changed it when I wasn't looking.
What I mean is, when you have a branch or do a split, there are red dotted lines where the two elements connect, but really, there's no baffle there. On the other hand, they're not open to the air (contributing to the 'terminus output' ), either. I was thinking if the lines were yellow (or something) it would indicate there was a path for the wave through the junction of the elements.
The horizontal frequency scale is marked by decades - .1, 1, 10, 100, 1000... - if you added '5's, that is, halfway markers, it would make it easier to count the lines and find, say, 60Hz.
Thanks for the other fixes and your attention to details.
Old 8th November 2012, 02:42 PM   #197
schmeet's Avatar
This is why I made them dotted lines rather than solid lines. Maybe if they were a light-grey or something they would be less 'obtrusive'.
Ah I see. Yeah that should be possible. I'll have a look.
Old 8th November 2012, 03:27 PM   #198
But both the closed end and the connected end are dotted lines. Solid lines would work.
(Start the program and branch the default. You can't tell which end of the branch is which. And the 'beginning' of '0', which was dotted before, is still dotted, so there's no indication that it now has a hole in it.)
Not, you know, that the graphic representation will ever be a perfect picture or this is any kind of a deal breaker.
Old 8th November 2012, 03:34 PM   #199
schmeet's Avatar
Yes, you're right.
Actual closed ends should have solid lines rather than the same dotted line...
Old 8th November 2012, 05:02 PM   #200
schmeet's Avatar
To celebrate #200 posts I have just uploaded another update!
Added a button to the enclosure window called 'Join'. If you select an element and click join it will look at its neighbouring elements and if they can be defined by a single element it will join them. This basically does the opposite of split.
Rejigged the enclosure window layout a bit. Let me know what you think.
Changed the way geometry is drawn:
Open ends have no line.
Closed ends have a solid line.
The 'join' between two elements is a dotted line.
Added '5s' to the frequency scale on all graphs.
Transmission Line Modelling SoftwareHide this!Advertise here!
TLwrx v 3.0 Transmission Line Software CarlosT Subwoofers 16 27th March 2008 04:25 PM
3 Way Crossover modelling Software? Grahame Multi-Way 3 13th May 2007 04:50 AM
Matlab-based triode modelling software Radames Tubes / Valves 1 16th September 2005 07:36 PM
3d modelling software greg_mcquaid Multi-Way 17 22nd May 2004 07:03 AM
