Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
Transmission Line Modelling Software
Old 26th September 2012, 03:28 PM   #11
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
Originally Posted by Keriwena View Post
Geometry input is straightforward. I'm guessing it's in meters?
Driver input... things I wanted to enter were greyed out.
The 'width' surprised me, I expected it to go the other way. Just what does the number mean?
Not sure what the API allows, but I'd like to see the tabs as separate windows. Yes, it's hard to focus on more than one window at once, but you get a peripheral sense of the size of the changes.
I'm curious, why can't you input '0' damping?
Anyway, nice work! I look forward to the next version.
Agree with Keriwena, I tried to to input a zero for the damping but the program returned a 1 or 0.001 but this didn't change the graphs at all.
Schmeet:
How did you find the way that you input the enclosure geometry
After more than 40 years of experience designing TL:s I have no problem to guestimate a plausible TL size for any driver without using any software.
When I first started using your program, I entered the correct TS directly into the Driver .Isd text file.
Prior to enter data into your program One need to know what to enter(Instructions of a work flow) and why(Explanations on how a TL is engineered). After pressing 'button' a note should show (confirming)that this action alters the design.
b
Old 26th September 2012, 04:20 PM   #12
schmeet is offline schmeet  United Kingdom
schmeet's Avatar
bjorno,
Thanks for the comparison. A couple of things:
I think you may have entered the Start Area and End Area the wrong way round on my software. Start Area is the closed end and End Area is the open end.
Also, what is the length and areas of the HornResp enclosure that you posted the graphs from? I am not used to HornResps input parameters...
As per my previous post, you can now input zero for the stuffing. My stuffing equation is very empirical and so there aren't really any units. But.. 0 is no stuffing, 0.2 is moderate and 1 is alot! It should (and does on mine) make a lot of difference.
Old 26th September 2012, 04:35 PM   #13
schmeet's Avatar
Ah, scratch that. I see what happened. You missed a zero out of the End Area so it ended up bigger than the start area.
Try it with 0.0031mē and zero stuffing and the graphs are almost identical to the HornResp ones. Phew! Thats a relief!
Old 26th September 2012, 04:56 PM   #14
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Originally Posted by Charles Darwin View Post
If you'd now make it work on MacOS too I would be an extremely happy bunny indeed!
+1
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 26th September 2012, 05:06 PM   #15
Originally Posted by schmeet View Post
bjorno,
The System length is 2.3 m; S1 area= Closed end and S4= the terminus. The driver is at an offset of 75.5 cm counted from S1.
You are right concerning the areas:By a mistake I entered the wrong value for the End area: I wrote 0.031 m^2 ,should be 0.0031m^2.
When entering the correct area the graphs became very congruent as should do.
Great Program!
IMO, Anyone who want to design a OD-TL (Offset Driver Transmission Line) can IMO with confidence use your program for achieving a good result.
b
PS: I will later (but not today) test the FR impact from the damping coefficients that can be entered. I think a comparison with MJK:s program would be very interesting.
Old 26th September 2012, 07:50 PM   #16
schmeet's Avatar
Just updated to version 2.2 (which you can update to via the About window).
The only change is that I have added options to the settings menu enabling you to alter the axis of every graph (min, max values and log/linear scale)
Old 26th September 2012, 08:05 PM   #17
pinkmouse is offline pinkmouse  Europe
pinkmouse's Avatar
+2
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 26th September 2012, 08:30 PM   #18
NEO Dan is offline NEO Dan  United States
NEO Dan's Avatar
Dan
Old 27th September 2012, 01:48 PM   #19
PB2 is offline PB2  United States
PB2's Avatar
Very nice work! Thanks for posting it.
Which model did you use for the calculations behind it, if you don't
mind my asking?
Driver parameters should be entered as:
Vas, Fs, Qms, Qes, Sd, Re, Le
and if I didn't forget any the rest can be calculated from them.
These are typically the minimum set provided by manufacturers.
It would be nice to have the total system internal volume calculated
on the Enclosure page.
I think it is nicely thought out and organized, the tabbed setup looks
fine to me but I could see where you might on occasion want more
than one open.
Old 27th September 2012, 02:22 PM   #20
PB2's Avatar
I coded around 1979 a simple TL simulator in FORTRAN that I ran on the college's DECsystem-10. It was very difficult to test and debug it and they complained about all the CPU time I was using for the complex math, LOL! I wanted to improve it over the years and thought about doing coupled sections exactly as you did it but never got around to it. Did you code this in VB.net? I'd assume you had a complex math library?
I am somewhat familiar with DEC computers (PDP-11, VAX) but never knew exactly what the DECsystem-10 was. I knew it was a timeshare system and I just found this info about it. It was getting close to the end of production - 1983 when we had it:
http://www.columbia.edu/cu/computinghistory/pdp10.html
Transmission Line Modelling SoftwareHide this!Advertise here!
TLwrx v 3.0 Transmission Line Software CarlosT Subwoofers 16 27th March 2008 04:25 PM
3 Way Crossover modelling Software? Grahame Multi-Way 3 13th May 2007 04:50 AM
Matlab-based triode modelling software Radames Tubes / Valves 1 16th September 2005 07:36 PM
3d modelling software greg_mcquaid Multi-Way 17 22nd May 2004 07:03 AM
