Transmission Line Modelling Software - Page 11 - diyAudio
Go Back   Home > Forums > Design & Build > Software Tools
Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
Old 7th October 2012, 08:28 PM   #101
Hi Mosquito
I would assume you just add another elemt with the end area smaller than the start area.
Hi from
Bjorn
Old 7th October 2012, 09:11 PM   #102
Mosquito's Avatar
Ok,I think I catch it. The MLTL is two element , the box and the port. Each one with equal start and end areas , the port areas being a lot smaller , of course.
Now I'll check if it works.
J
"It is less serious than if worst"
Old 7th October 2012, 09:26 PM   #103
Mosquito's Avatar
Yes, that's the way
J.
Old 8th October 2012, 09:19 AM   #104
schmeet is offline schmeet  United Kingdom
schmeet's Avatar
That's correct Mosquito.
Old 8th October 2012, 12:07 PM   #105
thunk303's Avatar
Great Job Schmeet.
I was wondering how easy it would be to have the option of choosing between a round or square enclosure?
And as mentioned earlier, to be able to select between different input measurements (eg... cm2 / m2 etc)
Keep up the good work and don't get too distracted by Android world, we need you in PC world.
Dean
Old 8th October 2012, 02:06 PM   #106
schmeet's Avatar
Originally Posted by thunk303 View Post
Great Job Schmeet.
Dean
Unit conversions is on my list of things to do, but tbh it will be on the bottom of the list for a while!
Regarding enclosure shape. i have plans to make the geometry viewer and bit more fully featured and enclosure shape will have some impact here. But as far as response calculations go. I do not calculate modes cross-modes and so the enclosure shape (in cross section) doesn't make any difference. Only its area...
Old 14th October 2012, 01:07 PM   #107
Mosquito's Avatar
Hi, again
One last question
I'll like to confirm that "driver position ratio", (enclosure dialog box),
means the distance, in meters, from the driver center, to the closed end.
thanks
J.
Old 14th October 2012, 07:11 PM   #108
No, it means the ratio of the driver position (from the closed end) to the total length. Using the Geometry window, you can see if you set the length to 4m, and the DPR to .5, the driver will be half-way down the pipe, which would be 2m.
Old 14th October 2012, 07:17 PM   #109
For a name, I suggest Leonard Lines.
BTW, the splash screen isn't updating the version number.
Old 14th October 2012, 07:29 PM   #110
schmeet's Avatar
Thanks for the heads up on the splash screen I'll fix that...
TLwrx v 3.0 Transmission Line Software CarlosT Subwoofers 16 27th March 2008 04:25 PM
3 Way Crossover modelling Software? Grahame Multi-Way 3 13th May 2007 04:50 AM
Matlab-based triode modelling software Radames Tubes / Valves 1 16th September 2005 07:36 PM
3d modelling software greg_mcquaid Multi-Way 17 22nd May 2004 07:03 AM
Copyright 1999-2017 diyAudio
