| Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators |
#91 | |
Hi from Wonderful Copenhagen |
#92 |
I almost forgot, one last suggestion. Things would go a lot smoother if things just updated automatically without the having to click the "update" button every time you make a change.
#93 | |
![]() I think it may be even less apropos in a TL program where it's not uncommon to change several entries at once. |
#94 |
While it is possible to do that in code, it can be quite painful to implement. I go through stages where I try to do changes on the fly and other times I prefer to use a update button. The problem with real time changes is you have to spend a lot more time trying to catch errors.
For example deleting all of the data out of a box in real time will throw up one type of exception, type a letter where a number should be will throw up another, where as you use an update button it can check all of the data in one go and tell you if you have it right or wrong before it crashes anything. Edit: Forgot it has to check for double decimal points etc (while a decimal point is a valid entry and therefore you can't exclude it from acceptable characters, you only want the one), I have written code to check for all these things, and it can be quite handy for an application like this where you are dealing with a lot of decimal placed numbers, as you can use the same bit of code for numerous boxes. Last edited by Silent Screamer; 3rd October 2012 at 11:33 PM. |
#95 |
Not sure if you plan to offer imperial conversion to those that don't speak native metric.... but here is a bit of code I wrote that works quite well for a two way conversion, you are most welcome to use it in your app.
Imports System.Math Public Class Conversion Dim Position As Integer Dim FirstPart As Integer Dim SecondPart As Integer Dim ThirdPart As Integer Const checkString As String = ".0123456789" Public Function UnitConversion(ByRef ConvertMe As String, ByRef Metric As Boolean) As String Dim charArray() As Char = ConvertMe.ToCharArray Dim aBool As Boolean = False For i = 0 To charArray.Length - 1 If CBool(InStr(checkString, charArray(i).ToString)) = False Then If charArray(i).ToString = "/" Then SecondPart = CInt(ConvertMe.Substring(Position, (ConvertMe.IndexOf("/") - Position))) Position = ConvertMe.IndexOf("/") + 1 Else FirstPart = CInt(ConvertMe.Substring(0, ConvertMe.IndexOf(charArray(i).ToString))) Position = ConvertMe.IndexOf(charArray(i).ToString) + 1 End If aBool = True End If Next If aBool Then Metric = False ThirdPart = CInt(ConvertMe.Substring(Position, ConvertMe.Length - Position)) ConvertMe = CStr(Round((FirstPart + (SecondPart / ThirdPart)) * 25.4, 4)) Position = 0 FirstPart = 0 SecondPart = 0 ThirdPart = 0 Else Metric = True Dim Reducer As Double = CDbl(ConvertMe) Dim Inches As Integer = CInt(Int(Reducer / 25.4)) 'Find the number of inches Reducer -= Round(Inches * 25.4, 7) 'Subtract off the inches (out to 7 decimal points of accuracy) Dim SixtyFourths As Integer = CInt(Int(Reducer / 0.396875)) 'Calculate the number of 64ths Reducer -= Round(SixtyFourths * 0.396875, 7) 'Subract off the 64ths calculated If Reducer > (0.396875 / 2) Then SixtyFourths += 1 Dim denom As Integer = 64 'The denominator starts off at 64 If CBool(SixtyFourths) Then 'If the number of 64ths is not 0 {even inches} Do While (SixtyFourths And 1) = 0 'Do while number of SixtyFourths is even SixtyFourths >>= 1 'Divide SixtyFourths by 2 (shift one bit to the right) denom >>= 1 'Divide the denominator by 2 Loop If CBool(Inches) Then ConvertMe = String.Format("{0}-{1}/{2}", Inches, SixtyFourths, denom) 'Format inches and fraction Else ConvertMe = String.Format("{0}/{1}", SixtyFourths, denom) 'Format the fraction End If Else ConvertMe = String.Format("{0}", Inches) 'Format inches only End If If Reducer <> 0 Then ConvertMe = "~" + ConvertMe End If Return (ConvertMe) End Function End Class |
#96 | |
When you are going through several iterations of a design trying to perfect it, just making single, small changes each time, that update button is going to get very annoying. Certainly not unmanageable but annoying nonetheless. Last edited by just a guy; 4th October 2012 at 12:59 AM. |
#97 |
That's doable through something like "lose focus" you click away and it performs the check / update. But whether you do it in real time or after you leave the box it still needs to check the validity of the value, and have some means of fixing the value should you have it wrong.
#98 | |
Quite the opposite in fact... if you're making small changes, having the "Apply" button allows you to focus on the graphs and the way they change as you click the button. If it just updated after text entry you might constantly be wondering if it changed, or by how much. Add to this the incredibly obnoxious tendency of programs like winISD to throw errors when you delete the value in a box, and I think it's not worth the trouble. My vote would be for the button to stay. By the way, I checked a ported enclosure simulated in winISD and this program, and they agreed nicely with the same parameters in both programs. Not a guarantee, but it's a good thing. Cheers, Owen |
#99 | |
Maybe we aren't picturing the same thing, there also wouldn't be any error when you clear an input box, no changes would be applied until you left that input box. |
#100 |
Hi, a question about this soft
It's feasible to model a MLTL, tricking the enclosure parameters some way, like this? Thanks J.
I know how to walk over grapes |
| TLwrx v 3.0 Transmission Line Software | CarlosT | Subwoofers | 16 | 27th March 2008 04:25 PM |
| 3 Way Crossover modelling Software? | Grahame | Multi-Way | 3 | 13th May 2007 04:50 AM |
| Matlab-based triode modelling software | Radames | Tubes / Valves | 1 | 16th September 2005 07:36 PM |
| 3d modelling software | greg_mcquaid | Multi-Way | 17 | 22nd May 2004 07:03 AM |
