3 Band Equalizer for Amp - diyAudio
Go Back   Home > Forums > Design & Build > Software Tools
Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
Old 30th July 2012, 05:31 PM   #1
Default 3 Band Equalizer for Amp
I recently built a modified 1957 Fender Deluxe tube amp. Even built the cabinet by hand.
For my senior project I'm working on a simple 3-Band Equalizer for the Amp. My design has to meet these specifications.
The Equalizer Pedal will be powered using a 9V battery
A push button will turn the foot pedal on and off
A minimum 3-band equalizer will be designed
Low (Bass) center frequency band: 78Hz (5% tolerance)
Middle center frequency band: 1.15kHz (2% tolerance)
High (Treble) center frequency band: 7.8kHz (2% tolerance)
At least +/- 15dB per band
Above is what I have so far. 3 simple band pass op amp circuits with some extra resistors to set the gain. I have the push button switch wired, just not shown. I'm running into problems getting the gain I want, frequencies not matching what I want on bode plot, and I'm not sure how I'm going to use potentiometers to create +/- 15dB per band.
Any and all help will be much appreciated. Getting pretty stressed out over this.
Old 31st July 2012, 01:14 AM   #2
Nice woodwork Joshwa! May I suggest you find a way to hold the tubes in place, they are way to expensive to loose!
About your circuit (we've been there before!), it will not do what you want it to do. You have 3 BP filers that, on a frequency sweep, will give you 3 adjustable bumps. Go to http://www.all-electric.com/schematic/mix-eq.htm and simulate or build the circuit on the bottom left. E
PS: You should also have a combining network (fancy term for 3 resistors) on the output of the ICs in your circuit before the signal goes to the next stage. R values depend on the output impedance of the ICs and the load. E
Old 31st July 2012, 04:36 PM   #3
Thank you for the complement and helpful information Mickey. =)
I've tried circuits 2 & 5 before. I can't calculate +/- 15 db of gain using the gyrator circuit (circuit 2). Correct me if I'm wrong but circuit 5 looks like a modified baxandall circuit in which calculating the mid frequency and gain becomes very complex because it relys on the bass and treble values.
I figured I'd try to design as simple of a circuit as possible to meet my specifications.
Old 3rd August 2012, 03:23 PM   #4
Does anyone know anything about a combining network to combine my band pass filters?
NEUMANN 3-band equalizer refference Analog Line Level 0 21st November 2009 01:58 AM
5 Band Graphic Equalizer NSLogan Chip Amps 2 17th June 2009 04:52 AM
quality 10 band Equalizer space2000 Solid State 5 26th May 2008 08:47 PM
need equation for 3 band baxandall equalizer prorms Solid State 8 14th December 2006 03:24 PM
RE: 7 or 10 or 12 band equalizer vignesh105 Parts 0 2nd May 2004 08:04 AM
Copyright 1999-2017 diyAudio
