Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
Spice problem or Design issue with differential Amplifier
Old 20th June 2012, 03:31 PM   #11
Nubcakes is offline Nubcakes  United States
Oh boy... That looks like a nightmare with AB amps. Before I get too involved, do they make any small audio transformers (no larger than 12mm in any dimension) with good frequency response in the range of 20 hertz to 20K hertz? The power output would be from 10mW to 500mW. I wouldn't mind using small transformers if I could find decent ones. All the ones I've found have really bad quality outside of like 500~10K hertz
Old 20th June 2012, 08:26 PM   #12
geraldfryjr is offline geraldfryjr  United States
Yes, I have seen them but they are not cheap!
Jensen is one company that comes to mind.
Lundahl is another.
JENSEN TRANSFORMERS, INC. - ISO-MAX® Audio Isolator Products
Lundahl Transformers, audio transformer and tube amplifier transformer manufacturer
Here is a search page from Mouser that may help you,
Transformers Audio & Signal | Mouser
Here is just an example of one of the Jensen transformers,
http://www.jensen-transformers.com/d...s/din2lofl.pdf
And also Sowter,
SOWTER AUDIO TRANSFORMERS
SOWTER PRE AMP/ LINE AMP TRANSFORMERS
Just to name a few.
Jer
Old 20th June 2012, 11:34 PM   #13
It shouldn't be any more of a problem then your typical BTL configuration except for the higher current handling of the VGamp in which would be just a matter doubling (paralleled) of the output devices.
Also running the VGamp in a Class A mode might be a good idea as well in fact running all three in a Class A mode may not be as efficient but it would guarantee the possibly of a higher sound quality.
FWIW
jer
Old 21st June 2012, 04:16 PM   #14
macboy is offline macboy  Canada
"guarantee the possib[ilit]y of a higher sound quality"
That sounds like audiophile marketing speak... just shy of making an actual specific claim (by adding wording like "possibility of" to the claim) so that it doesn't need to be proven to be true.
Old 21st June 2012, 05:00 PM   #15
Well from my understanding Class A Amps are the rolls royce of Audio Amplifiers. They provide pretty much supreme quality at the dreaded cost of efficiency. I think I read somewhere that the efficiency could be good if you were driving a signal close to the limit of the amplifier continuously. Otherwise your efficiency will be proportional to the limit of the amp since Class A amps are fully "on" all the time.
Old 22nd June 2012, 03:50 PM   #16
I uses the word "possibility" as the term "theoretically".
We already know what Class A mode is and has already been proven to be what it is.
This doesn't mean the a class AB mode amplifier can not produce a good sound quality.
In fact the class AB pushpull amps as in the schematic are already running in a Class A mode as long as the peak current flowing into the load is not more than the quiescent current flowing through the output devices.
If the peak load current exceeds the quiescent current of the output devices then it is considered to be in a Class AB mode unlike Class B because the output devices are never ever in an off state.
The efficiency of a Class A amplifier is quite low typicaly around 10% to 15% and no more than 25%.
But in a push pull Class A or a BTL Class A configuration the efficiency can be as high as 50%.
I suggested that the Virtual ground amp to be running in a Class A mode to help eliminate any crossover switching distortion because it will be spending must of its time near the zero crossing point.
This type of circuit also works with opamps and even they typical have a Class AB output stage.
It has been highly debated in many threads as to whether or not they (opamps) have Class A ,Class AB or Class B output stages and is irrelevant to the overall function of the circuit.
jer
Old 25th June 2012, 01:18 PM   #17
I didn't mean to question the statement about class-A amps itself, rather, I was just poking fun at the snake-oil-marketting-like wording that you had used.
Old 1st October 2012, 12:08 AM   #18
Time for some thread necromancy! Click the image to open in full size.
So the project that I needed the amp for got OK'd and I've been adjusting the amp design a lot. I've think I got it optimized as much as I can while maintaining minimal cross over distortion.
There is something that has been bothering me though. When I build the amplifier on bread board and test it, I can't draw much more than 630mW of power before the signal starts clipping at both peaks (regardless of load). LT spice shows that I should be able to get around 1284mW (using a 4 Ohm Load in place of the 8 Ohm one) before it starts clipping. I obviously don't expect to get as high as LT spice says I can, but I'd like to at least get 750mW.
The signal going into the AB-amplifiers doesn't drop much or clip with a 4 Ohm load connected, but for some reason the signal is getting lost/reduced and clipped coming out of the AB-stage transistors. I ran through the equations for it several times and it's not matching up with what I am actually seeing.
Any ideas I could try?
Spice problem or Design issue with differential AmplifierHide this!Advertise here!
My new design of differential buffer I/O board for fully balanced design alant4321 Solid State 28 28th July 2011 09:53 AM
Differential push-pull design question Tyimo Tubes / Valves 4 15th January 2010 07:05 PM
Differential filter circuit: biasing problem Alex M Tubes / Valves 4 5th May 2009 09:44 AM
Differential to differential amplifier Cauhtemoc Solid State 3 15th August 2007 07:39 AM
differential amplifier Thomas Giz Digital Source 1 23rd March 2003 08:07 PM
Copyright ©1999-2017 diyAudio
