Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
Audiotester, now what?
Old 27th May 2012, 11:19 PM   #1
MelB is offline MelB  Canada
Default Audiotester, now what?
Alrighty, I have never used one of these computer software programs before.
I have audiotester all set up and I think I am getting proper results.
Here is my line amp under test. So a couple of questions:
Does it look like I am getting proper test results?
What are the standard FFT's that people are running and using to compare? (2D or 3D or distortion or IM or noise) I have no clue.
Old 28th May 2012, 04:30 PM   #2
euro21 is offline euro21  Hungary
Yes, it is proper result....it shows that your preamp distortion a bit high.
Second (first is the fundamental -in this case 1KHz-) harmonic level 40dB (1/100) below the fundamental, and third -60dB, so THD (Total Harmonic Distortion) about (over) 1%.
Old 28th May 2012, 06:38 PM   #3
Thanks!
I have managed to switch over to the ASIO.dll.
Now I get this (attached) All else being equal..the distortion is magically better?
The ASIO is allowing a higher bit resolution OR I may have been able to use more bits with the Windows drivers and just did not know it?
Steep learning curve with this.
This is Windows 7 64bit with Audiotester (latest version) into a M-Audio Delta 1010. Using channels 7 and 8 (-10dB) Calibration value 800mA.
Old 28th May 2012, 06:50 PM   #4
On Hiatus
SY's Avatar
ASIO is squirrelly with my XP machine, worked much better with my (hate to say it) Vista computer. In any case, yes, your distortion is a bit high, but you may want to check levels using a scope or AC voltmeter to make sure you're not running them too high and overloading the preamp or your soundcard input.
Usually I use a loopback in one channel to verify that the soundcard is working properly.
Audiotester is amazingly versatile but it does take a solid understanding of FFTs and a lot of playing around to get things working right. And technical support is basically nonexistent.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 28th May 2012, 08:10 PM   #5
Thanks SY. Ya that was with almost 2v RMS out of my pre-amp.
I am going to follow along with the active thread here on Visual Analyser. Looks like my timing is good to get in on the ground floor on setting up this software.
Audiotester is being very buggy for me...it starts making popping sounds after a while when the frequency generator is running and the only cure is to reboot.
Old 28th May 2012, 08:15 PM   #6
Oh, I case people have not checked lately. M-Audio has new sound card drivers as of March 2012.
Old 28th May 2012, 08:15 PM   #7
On Hiatus
SY's Avatar
If you get pops and similar issues, try increasing buffer size.
Old 28th May 2012, 08:31 PM   #8
Pano is offline Pano  United States
Pano's Avatar
I applaud your decision to move over to Visual Analyzer. Like many, I had given it a short look and moved away. That was wrong, it's amazing software.
Pop and clicks can be other activity on your computer. Somewhere there's a thread about that and links to tools. SY, you remember?
Take the Speaker Voltage Test!
Old 28th May 2012, 08:43 PM   #9
On Hiatus
SY's Avatar
Yeah, I had a thread about that. Usually, the buffer size will fix things, but it didn't for me. The solution for that particular computer was to change the OS to 7 and disable the wireless and LAN on startup. This was for music playback, not measurement.
Old 28th May 2012, 09:03 PM   #10
Pano's Avatar
Somewhere on this computer I have the tools. Will dig. Turning off wifi helps here, tho there are still some interrupts.
Audiotester, now what?Hide this!Advertise here!
FFT question with audiotester zigzagflux Software Tools 14 12th January 2012 08:52 PM
Audiotester + M-audio - info + question pmillett Tubes / Valves 24 29th June 2008 04:19 PM
E-mu 0202 + audiotester dave slagle Tubes / Valves 18 28th June 2008 01:28 PM
AudioTester 2.2 Calibration Tyimo Multi-Way 0 29th March 2007 05:34 PM
Hellp with AudioTester 2.1 a007udio Multi-Way 6 24th March 2007 12:26 PM
