Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
Spice oddity. Is it me or a glitch ?
Old 16th April 2012, 10:57 AM   #1
Mooly's Avatar
Default Spice oddity. Is it me or a glitch ?
Can't figure this one out.
The circuit (which is just a doodle) initially has a DC servo and simulates just fine. This is picture #1 below. I then record the DC voltage at the servo output and sustitute the servo with a fixed voltage source. Again the simulation is fine.
Now for the strange part.
Not wanting the servo I start to delete it component by component using the "scissors" to remove each bit. When I get as far as deleting the opamp or V1 the main circuit suddenly fails to simulate. The main amp output just rises to the positive rail. It also ends up with a B-E voltage of 30 volts across Q1 (Emitter most negative). I can delete the 1 Meg, and the 0.1uF and V2 and their traces and the circuit is still fine. When I come to delete either the opamp or V2 it fails.
I can get as far as in picture 2. Up to this point the circuit simulates correctly. If I now delete anything else to do with the servo it fails. I even altered the voltage V1 to zero and that made no difference either.
Is it me or is there a glitch somewhere ? I can't see where I am going wrong.
Old 16th April 2012, 11:04 AM   #2
3.1V of error correction is enormous. That made me look at the standard (without DC servo) circuit.
You have no route for the input offset current to return to source or ground.
If that 3.1V is out by a tiny amount, the output offset will rocket.
regards Andrew T.
Old 16th April 2012, 11:07 AM   #3
Mooly's Avatar
Hi Andrew,
It's single ended so the 3.1 volts is OK. It a bias voltage rather than than an error correction.
I can't see where the interaction come in between the opamp and V1 in picture 2 and the main circuit. It's OK up to this point.
Old 16th April 2012, 11:11 AM   #4
can you remove the 3.1V error correction (you can call it bias if you want) and replace it with the normal ground referencing resistor to allow the input bias current to flow to source/ground.
The amplifier should then bias itself to a reasonable output offset and you can then apply error correction to that if needed.
Once that is done, maybe then Spice will allow you to delete the last of the DC servo components and any definitions that go with them.
BTW,
may I remind you I am not a prepackaged simulator software user.
The (very simple) modeling I do, is on my own software.
regards Andrew T.
Old 16th April 2012, 11:12 AM   #5
Mooly's Avatar
This is what happens. Look at the difference in the pictures (opamp).
Old 16th April 2012, 11:16 AM   #6
You still have that forced error correction.
That rise in voltage looks like charging of C1 (?)
Let the input find it's own bias for the input offset current.
regards Andrew T.
Old 16th April 2012, 11:16 AM   #7
Mooly's Avatar
The input of Q1 has to be biased to around 3 volts or so. I could rig a fixed bias divider up to try.
I've to go out shortly but keep the ideas coming
Old 16th April 2012, 11:19 AM   #8
Is it a +3V or -3V on the base of the input transistor?
Let it do it's own biasing with the normal ground referencing resistor.
regards Andrew T.
Old 16th April 2012, 11:21 AM   #9
Mooly's Avatar
I agree it does look like C1 charging. Then there is the 30 volts across B-E of Q1. That doesn't sound right in that I would expect it to break down or zener at around 8 volts although I guess that's maybe a "model issue".
Old 16th April 2012, 11:23 AM   #10
Mooly's Avatar
It's minus 3
Spice oddity. Is it me or a glitch ?Hide this!Advertise here!
Intermittent DCX2496 glitch ComputerJLT Digital Line Level 4 26th January 2012 03:53 AM
JFET CS design, how? (and possible SPICE oddity) StefanTH Solid State 4 23rd October 2008 10:24 AM
P-P resistance oddity Carlp Tubes / Valves 6 30th October 2006 02:49 AM
Is this glitch ? Bernhard Digital Source 4 11th April 2005 01:35 PM
Working amp witha glitch - or two. lazyfly Solid State 5 21st June 2004 03:24 PM
Copyright ©1999-2017 diyAudio
