| Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators |
Does anyone know how to find the component values for the attached RIAA network?
I am building a tube differential phono stage and will verify it spice. |
#2 |
Where's the input and output?
You also need to take into account the source and load impedances. |
#3 |
More specifically, the circuit is like this. The network is between the two differential outputs.
#4 |
Look here, this seems to be the equivalent topology to what you have in mind :
phonostage General information : Cut and Thrust: RIAA LP Equalization | Stereophile.com And in LTspice, a reference can be simply constructed with an AC voltage source of magnitude 10 connected to an "e"-source (VCVS) with the transfer function given in direct Laplace notation, using the known time constants : laplace (1 + 318u*s) / (1 + 3180u*s) / (1+ 75u*s) Comparison with the Stereophile article shows 100% precise accuracy (compare the detailed numbers given in the text) as expected right away, but always better double check Last edited by KSTR; 26th March 2012 at 08:22 PM. |
#5 |
I think it is Harm that gives a method to determine the component values.
There is also a method given by one of our audio celebs, Bax or JLH or ?? |
#6 |
Calculation, for a starting point, is quite straightforward. RIAA EQ is a one decade wide bass shelf (from 50Hz to 500Hz) with a pole on top (at 2.1kHz). Problem is the somewhat ill-defined plate impedance of the tubes for the actual circuit which influences all three time constants, being part of the source impedance the network works upon.
#7 |
I've attached the topology you want. There's an RIAA calculator here: KAB Electro Acoustics http://www.kabusa.com which you can use as follows.
Connect the two resistors marked R! in my drawing to the 12AX7 plates. For the R1 value in the calculator, use 2 times R1 in the drawing plus two times the source impedance of the driving stage (the formula for the source resistance of a diff amp may be found in Morgan Jones's "Valve Amplifiers" as well as any other standard tube text. The other components can be directly plugged into the KAB calculator.
If there's a sucker born every minute, where do the rest of them come from? |
#8 |
Tried it in simulation. I receive what resembles an RIAA curve, but the voltage differential is supposed to be reasonably flat, as I am running inverse RIAA networks on the inputs, along with the sine wave generator to simulate a cartridge.
The plate impedance for a 12AX7 is around 70k, in parallel with 220k, and double those quantities is about 560k. I put the values in the calculator and came up with the values in the schematic below. I wondered if I calculated it properly? |
#9 |
You really do want to incorporate the build-out resistors- that will lower distortion, especially at high frequencies, and reduce the dependence of the frequency response on tube aging and drift. There is something of a noise penalty there, unfortunately. There are also ways around that, but with added complication.
Let's pick 100k as the buildout resistor. The equivalent series resistance is then 200k + 2x RL||Rp. The second term is about 53k, so the total equivalent resistance is 306k. Plugging that into the KAB kalculator, R2 is 44k5, C1 = 7n15, C2 = 2n45.
#10 |
What are the build-out resistors? Where do they go?
| transfer function | jenks | Solid State | 31 | 24th April 2008 08:28 PM |
| Sound card transfer function | NIC1138 | Digital Source | 9 | 15th July 2007 12:15 AM |
| Transfer Function | jclouse | Multi-Way | 22 | 1st July 2006 01:19 PM |
| SPICE transfer function for RIAA testing | Onvinyl | Analog Line Level | 28 | 3rd March 2006 05:40 PM |
| Transfer function of closed box | cm961 | Multi-Way | 1 | 31st August 2004 06:42 PM |
