Go Back   Home > Forums > Design & Build > Software Tools
Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
Old 25th September 2012, 08:53 PM   #21
xjr100 is offline xjr100  Europe
Have not tested your software yet, but good feature could be if you bind crossover, box_ simulation and measurements in "project". I've tried several design tools, but important thing is to bind schematics, simulation and real measurements to compare diffrent results and do not forget which measurement is for which crossover version.
Old 26th September 2012, 07:25 PM   #22
Hello xjr100,
It is also possible to compare projects within Sofmea. To do so, you have to save curves when you simulate or optimize the crossover (checkbox on the top, near the optimize button).
Then rename manually the files created in the working directory, for example adding the crossover paramerters in the filename to be able to identify the file later...
Finally, go to the Visualize Menu in order to visualize a curve and uncheck "Make a new print". Set the scale and you will be able to plot different curves on the same graph, each time choosing a different color if you want to.
I hope it will help you
Correct Way to measure a horn loudspeaker mwmkravchenko Subwoofers 28 1st April 2009 01:51 AM
crossover question Measure at 2500? ben62670 Multi-Way 6 1st January 2007 03:18 PM
First loudspeaker design with crossover Jiggity Multi-Way 19 30th July 2006 11:07 PM
How to design Crossover circuit of the loudspeaker using accuton ceramic driver unit? kevinlin1013 Multi-Way 9 20th August 2005 09:47 PM
loudspeaker/crossover design software phreeky82 Multi-Way 11 2nd August 2003 06:46 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
