Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
LTSpice FFT simulation settings and inconsistent results.
Old 20th June 2013, 11:25 PM   #101
jcx is offline jcx  United States
I like looking at the FFT plot, and with multitone excitation - THD really doesn't do much for me
Old 21st June 2013, 06:12 AM   #102
Mooly's Avatar
I haven't, its interesting but I've to much on the go at the moment to take the time to figure it all out
Old 24th June 2013, 08:43 AM   #103
padamiecki is offline padamiecki  Poland
this is exactly like me
regards, Pawel
Old 24th June 2013, 08:48 AM   #104
Originally Posted by jazbo8 View Post
Did you guys try the THD Analyser? Seems like an interesting approach, even for non-LTSpice user like me ;-)
no, unfortunately not,
it seems for me too difficult find to downloading it, then put to the right place in ltspice, and then setting those parameters
however I can see that this is very helpful thing!
regards, Pawel
Old 24th June 2013, 09:11 PM   #105
jazbo8 is offline jazbo8
jazbo8's Avatar
Could you guys post some example of the FFTs with multi-tone, are you using any particular standard such as SMPTE, CCIF, etc.?
Old 25th June 2013, 01:08 AM   #106
keantoken is offline keantoken  United States
keantoken's Avatar
The simplest multi-tone analysis is just two sine waves, frequency shifted so they heterodyne to make a signal with a sine-shaped envelope. This is basically the same thing as a sine-burst signal. Here is a amp test rig I made set up for CCIR.
If you want to do multi-tone analysis you must really remember the "noise floor" in SPICE doesn't mean anything, and it has to be low enough before you will get meaningful results. A high noise floor in simulation indicates the simulator is not set up optimally. This rig attempts to correct that.
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
Old 25th June 2013, 01:14 AM   #107
jazbo8's Avatar
Thanks, this is very useful information.
LTSpice FFT simulation settings and inconsistent results.Hide this!Advertise here!
Distortion simulation with LTspice tiagor Solid State 32 22nd December 2012 09:33 PM
Help needed in running LTSPice FFT simulation on the M1 Lateral FET amp Mooly Solid State 11 24th February 2012 06:44 PM
Latest LTspice giving crazy FFT results ray_moth Tubes / Valves 5 6th May 2010 07:07 AM
About LTSpice Simulation. nicholas1113 Solid State 2 15th November 2009 07:52 AM
How to make sense of LTSpice FFT analysis? ray_moth Software Tools 11 12th August 2008 07:43 PM
