| Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators |
hello
![]() just wanna know how to convert all my itune files to higher smpling rate.maybe 48 or 96bit, that's good enough for me.i have pc and mac with a little bit knowledge on computer..... where to start? thanks and more power. |
#2 |
There's really no point to converting...the resolution of your file is limited to whatever the original source was and you won't get any benefit.
Kevin(ahcc20)...I'd rather have a bottle in front of me than a frontal lobotomy! |
#3 |
There's nothing to be gained from upsampling the files, they will be oversampled in your dac anyway, there is no possible benefit.
hoping to pick up some things. |
#4 |
I won't comment on the value of software upsampling, but if you use a player for iTunes, like PureMusic for example, it can upsample they way you want it to I believe. I use PureMusic and it is a great player, but I try to play in native sampling and let the DAC upsample if i am using an upsampling DAC or not if I am using a NOS DAC. I doubt I could hear much difference and unless your computer has extra memory and a fast processor, which mine don't, you are better off taxing the playing computer less.
#5 |
At the risk of sounding like a jerk... There's and old saying that translates as <GIGO> which means "Garbage In Garbage Out." It's not a diss but means that if you have a "lower" quality audio file, there's really no way way to recapture the original quality because you're essentially stuck with what you were handed. This doesn't mean that you can't re-eq and otherwise "filter" the track...
Good luck, A. |
#6 |
Pure Music. Is this a conspiracy to make me break down and buy a Mac? I have found no PC based music player I am happy with.
Oversampling does nothing but make the integrator job easier. But, are there any more advanced processing techniques that can do a better job of guessing with off-line processing? I am about to start saving all my CD's with EAC and then convert to the flavor of the day. I don't want to do it twice as I have about a thousand to save. |
#7 |
What's wrong with FLAC as a storage format? I have about 14000 FLAC files and feel no need for anything else.
Also: JRiver and Foobar, among others, allow up-sampling. Depending on your output device it can make no difference or some difference. |
#8 |
+1 on FLAC as the library file format of choice.
| Need software to convert Alesis DR16 files | cloudhopper | Digital Source | 0 | 15th April 2010 03:36 PM |
| How can I convert media files? | Jefferson.diane | Digital Source | 4 | 27th November 2007 11:56 PM |
| Page generated in 0.09709 seconds (75.93% PHP - 24.07% MySQL) with 10 queries |
