| Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators |
I just learned there is software to simulate op amp circuits. But honestly I am lost. --- Which software to use //prefferably free, or capable to do that in demo mode to simulate a circuit: http://oi44.tinypic.com/xfugaw.jpg //this is going to be a shelving filter to sweep through the circuit f.ex. 30-10 000Hz and plot the frequency response as a graph? //frequency vs db level Best Regards p.s. could it be done in 5spice? have installed it and have drawn the circuit but don't really get it. not even sure if it is possible to be done in this application also, I use some generic symbol for OP, can i load a model for LM833 instead??? Last edited by emosms; 29th January 2012 at 02:11 AM. |
#2 |
almost got it
#3 |
Many here use the free powerful (but VERY user hostile) LT SPICE.
As a new user, you might find the free version of TINA available as a download from TI, to be much easier to use, and will do all you need. |
#4 |
You can use an 'ideal' op-amp in many versiions of SPICe (as in the attached TINA circuit) to check the basic operation, then replace it with the real op-amp model later.
| Instek GFG-8255a sweep/rate vs sweep/time | perfknee | Equipment & Tools | 5 | 20th January 2011 03:06 PM |
| op-amp with filter for active monitor? | jayless | Chip Amps | 1 | 17th March 2010 11:55 PM |
| OP based low pass audio filter | tolaemon | Chip Amps | 8 | 27th September 2008 04:19 PM |
| (test equipment) Filter....use as Xover ? | redrabbit | Subwoofers | 0 | 28th October 2007 04:54 AM |
| Active filter test software | 4real | Multi-Way | 4 | 5th October 2004 07:43 PM |
| Page generated in 0.06936 seconds (72.48% PHP - 27.52% MySQL) with 11 queries |
