| Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators |
hi everyone I'm looking for decent sound card to use with truerta and homemade test mic. nothing too fancy maybe around $60-80. I spend most money on my diy tube and speaker. my wife would kill me in my sleep if I spend more than that .any suggestion?
thank you nate |
#2 |
How about the Icicle at Blue Microphones
E |
#3 |
Is that a usb sound card?
#4 |
I used to use the M-Audio Transit with good results (or rather, I still use it but as far as I know M-Audio no longer make the part for some reason). It is a good choice if you can get hold of one.
#5 | |
Nate, For about $75 you can combine a Behringer UCA202 line level USB interface with a Xenyx 502 mixer. Just make sure the 502 is the newer model with phantom power. Meanwhile at $100 the Tascam US122-MkII is a very good USB interface with two mic inputs and line in/out. If you only need mic input and do not need to have line in/out available then either the Mic Mate or the Icicle would work at around $50. I have links to most of these products here: True Audio: Audio Spectrum Analyzer and Loudspeaker Design Software Regards, John
John L. Murphy Physicist/Audio Engineer |
#6 |
Uca202 and 502 sounds great ill check those out
Thank you for your help |
#7 |
I have Audiophile 192 M audio PCI
and True RTA There is beter than True RTA....(virtinis for free) And I think there may be beter than The M audio... Well at least in my case I think my mother board and set up is quite noisy and can get good results (noise floor at -80 dB) But others whit same set up have much beter results (noisse floor at -110dB) Probably if I had external card it would have been beter in my case but then there is the compromise in speed one have to make with the USB conection compared to PCI. When is usb 3 camming out? |
| PC sound card sound chips | kaluchka | Chip Amps | 6 | 20th June 2011 03:48 PM |
| Sound Card help | cobretti | PC Based | 11 | 13th March 2011 04:05 PM |
| Help needed choosing a design for live sound | Pyroibw | Subwoofers | 31 | 7th December 2010 04:36 PM |
| Which sound card? | MMeche | Digital Source | 1 | 28th June 2008 11:17 PM |
| Can your sound card do this? | jackinnj | Everything Else | 25 | 7th November 2005 11:32 PM |
