| Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators |
Does anybody have correct AD797A spice model ?
AD provided models does not simulate correctly. Under AC analysis, displayed gain is 60dB approx where as stated value is 20V/uV (146dB). I am using LTSpice-IV for simulation. If I am doing wrong please show me the correct way. AC source connected to Non-Inv (+IN) input, Inv (-IN) input is grounded, Output connected to 10K load. VCC=+15V, VEE=-15V V1 VCC 0 DC +15V V2 VEE 0 DC -15V VS 1 0 AC SINE(0 0 0) XU1 1 0 VCC VEE 2 NC AD797/AD RL 2 0 10K .AC DEC 1000 1 1e6 .END
Regards, Sameer Dhiman |
#2 |
don't use .AC sim until you have the circuit working in .Tran - it is very likely your output is at a rail in the inital operating point calculation
the "simple Middlebrook" loop gain probe is much better because you can measure with the feedback loop working - but it shows "loop gain" - which is more intersting for stability another simple way is to divide the output V by the differential input V - while the cirucit is in a working feedback amp Ltspice is free, has gui, schematic entry and waveform plotting .asc is the LTspice circuit file - just edit off the .txt extension Last edited by jcx; 6th September 2011 at 02:33 PM. |
#3 |
![]() I'll try after reaching home. At work I do not use GUI (hidden practice in spare time at work). I hope you will understand.
#4 |
Hi JCX,
Your suggested technique worked flawlessly ![]() Please clarify one doubt. If I use OPA227 spice model with .AC command it simulates correct open loop gain (160 dB) then why we had to measure open loop gain of AD797 from closed-loop ?
#5 |
there can be differences in the model, the circuit for the input offset V - maybe the 227 model has unrealistic "perfect" 0 offset V at the input
| Is it right the Spice model of MJE182? | fotios | Software Tools | 1 | 24th March 2010 09:31 PM |
| lamp spice model | radtech | Parts | 2 | 11th March 2007 10:19 PM |
| SPICE model | Prune | Parts | 6 | 16th October 2004 03:22 PM |
| Does anybody have an lm3886 SPICE model? | Faber | Chip Amps | 0 | 14th July 2004 12:31 PM |
| Spice model | doigtee | Tubes / Valves | 6 | 12th July 2003 11:42 AM |
| Page generated in 0.09103 seconds (73.28% PHP - 26.72% MySQL) with 11 queries |
