| Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators |
For an amplifier.
1. Remove/disable input/output filters from schematic. 2. Do an AC analysisis. 3. Probe output from amplifier and see CLG. Is that correct? I seem to have a a lot of trouble getting a decent CLG with enough Phase/Gain margin without huge LTP degen resistors, huge compensation caps which leads to low gain crossover frequency(100-200kHz) and it kills the slew rate. Thought I might be doing something wrong. |
#2 |
Are you sure you mean closed loop gain?
It so easy, see example: you obtain the gain immediately. But it will tell you little about the loop stability, you would have to look for peaking in the amplitude response and/or rapid phase changes. The normal tool for analyzing stability is OL analysis. Post your .asc circuit, it will be easier to show you for real what to do.
#3 |
Open loop gain can be tricky to simulate. In some cases the circuit stops working if you simply remove the feedback. I have had this problem myself and hope to learn something from this thread (will be taking notes).
If you show us the circuit we can take it from there. Make a copy of your .asc file with .txt extension and post that - the forum software will not accept .asc files. Last edited by ingenieus; 17th August 2011 at 01:16 PM. |
#4 |
You are interested in open loop gain/phase, not in closed loop gain.
Feedback should not be removed, because it will change parameters of the system, you are trying to analyze (even if you will not have problems with DC operating point). You need to keep feedback closed, inject signal inside feedback and measure ratio of signals on both ends of injector. For detailed methodology and explanations, check this link: Loop Gain Simulation - Frank Wiedmann
Audio Perfection |
#5 |
#6 |
Like this.
1. Shows Cordells proposed way of plotting the loop gain. 2. Shows LG from my own amplifier. If I have understood his eaxmples, methods and descriptions of these corretly, this should be correct. |
#7 |
Yes, I was thinking of Loop gain, "Loop gain" is the right term.
Audio Perfection |
#8 | |
Audio Perfection |
#9 | |
What you need is "Loop Gain". Attached pictures are showing the way to measure this in simulation, together with one more way to measure "Open Loop Gain".
Audio Perfection |
| Throwing away open loop gain with an opamp near or at unity gain | okapi | Pass Labs | 3 | 25th December 2009 01:23 PM |
| Lower closed loop gain? Higher slew rate. | fotios | Solid State | 4 | 27th July 2009 01:41 AM |
| Gain Blockwith Variable Loop Gain | Bonsai | Solid State | 17 | 11th July 2008 02:40 PM |
| Hump in Closed Loop Frequency Response -- Root Cause ? | EUVL | Pass Labs | 22 | 12th January 2007 01:20 PM |
| Opamp phase shift - open and closed loop. | Circlotron | Analogue Source | 8 | 23rd April 2003 07:06 AM |
| Page generated in 0.12451 seconds (79.44% PHP - 20.56% MySQL) with 11 queries |
