diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Software Tools (http://www.diyaudio.com/forums/software-tools/)
-   -   How can I do a 10 khz square wave with LtSpice ? (http://www.diyaudio.com/forums/software-tools/194024-10-khz-square-wave-ltspice.html)
tessier 4th August 2011 07:26 PM
Hi
How can I generate a 10 khz square wave with LtSpice ? (50 % duty cycle)
And how for a 31 khz square wave ?
Thanx
Paul
sawreyrw 4th August 2011 07:29 PM
Use a pulsed voltage source with the correct times. Note that Trise and Tfall should not be 0.
tessier 4th August 2011 07:41 PM
Hi
I don't know how to set the LtSpice pulsed voltage source for those frequency square waves.
Thanx
Paul
ingenieus 4th August 2011 07:53 PM
1 Attachment(s)
Add a voltage source to your circuit. Right click on it. A window like below should pop up. The values below gives a 10kHz square wave. Adjust for 31kHz.
tessier 4th August 2011 08:01 PM
Hi
Is it the Tperiod or the Ncycles that I have to adjust to get 31 khz ?
Thanx
Paul
Tekko 4th August 2011 08:07 PM
You can leave Ncycles alone since thats only how many cycles it'll give before it stops, leaving it blank will make a continous pulse train.
On Nperiod you put in the equivalent time for 31 kHz and Ton will be half of that value to define 50% duty cycle.
Rise and fall can be set to 1.
jaycee 4th August 2011 08:15 PM
Tperiod would be 1/31000.
Ton will be half that
You may do:
Ton = {0.5/<value in Hz>}
and
Tperiod = {1/<value in Hz>}
I would also use rise/fall times of 0.01u as this will give you a "perfect" square wave with no percievable rise/fall time.
tessier 4th August 2011 08:22 PM
Hi
So, to get 31 khz, I set Tperiod to 31u and Ton 15u ?
Thanx
Paul
jcx 4th August 2011 08:42 PM
1 Attachment(s)
for symmetry you need to set Ton = (1/2)*(1/f) - t_rise
use curly brackets, .param to save typing
Pano 4th August 2011 08:51 PM
:cop: Moved to Software forum
Resources saved on this page: MySQL 18.75%
Copyright ©1999-2017 diyAudio
