How can I do a 10 khz square wave with LtSpice ? - Page 3 - diyAudio
Go Back   Home > Forums > Design & Build > Software Tools
Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
Old 29th August 2011, 02:03 PM   #21
It's only a square wave.
JCX shows how much one needs to know before one can learn anything from LTspice.
Simply learning how to operate LTspice is near the end of the learning required.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 6th December 2012, 07:27 PM   #22
FdW is offline FdW  Netherlands
FdW's Avatar
This is what I use
;PULSE({{ogen}+{vgen}} {{ogen}-{vgen}} {250m/{fgen}} 0 0 {450m/{fgen}} {1/{fgen}})
.param fgen 10k; Frequency
.param vgen 100m; Volts
.param ogen 300m; Offset volts
Old 11th December 2012, 08:44 PM   #23
FdW's Avatar
And this works also
Old 23rd October 2013, 08:39 AM   #24
Cool This is how I do it
A bit late, but this is how I do it:
Add a voltage source to your window, set parameters:
PULSE(-2 2 0 0.1p 0.1p 0.05m 0.1m)
.tran 1ms
This gives you a square pulse source, with an p-p amplitude of 4 volts (+2, -2)
The attached pdf explains how to do it in detail. (I've made it for myself to remember)
Typical output is shown in the picture.
Last edited by toriversen; 23rd October 2013 at 09:04 AM. Reason: some typing errors
Old 29th March 2015, 10:46 PM   #25
Googled this. Great methods. Thanks to all!
LTspice square wave and audio amp test maouna Solid State 2 11th December 2010 10:34 AM
Sine wave - Square & Triangle wave generator using Transistors / OP-Amps lineup Solid State 20 9th October 2006 01:15 AM
10 KHz Square wave output? mura Solid State 17 31st May 2005 01:19 AM
Copyright 1999-2017 diyAudio
