| Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators |
#11 | |
I've try your param but it was not work ok. Can you show me a capture image of the LtSpice Fonctions window showing the pulse parameters. Thanx Paul Last edited by tessier; 4th August 2011 at 10:55 PM. |
#12 |
clik on the attachment thumbnail?
the line: .param f = 31k, t_edge=1u has to be entered in the <.op> tool pop up window (far right on toolbar) the line: PULSE(-1 1 0 {t_edge} {t_edge} {1/2/f-t_edge} {1/f}) is the "value" entry for the Vsource, usually entered in the dialog window but can be pasted in the pop up box when rt clking on the value [edit: paste the line in a Vsouce "Value", then rt cik Vsource body, you will see filled in parameters in window] add new named params to control additional sources, you can have f1 = 10k, f2 = 31k on the same schematic with the Vsources each using the appropriate parameter name Last edited by jcx; 4th August 2011 at 11:32 PM. |
#13 |
Hi
I was meaning the LtSpice Fonctions window like the image I show here. Thanx Paul Last edited by tessier; 4th August 2011 at 11:11 PM. |
#14 |
tessier,
Can't you figure out the period of a 31 KHz square wave? If not, you have a lot of work to do before you will learn anything from LTspice. Rick |
#15 |
honest questions without pretense are/should be welcomed
#16 |
Hi
The 31 khz square wave are working but it's all down on the negative side like you can see in my image. I've only used Ltspice with sine wave in amps simulations. Thanx Paul Last edited by tessier; 5th August 2011 at 12:06 AM. |
#17 |
OK Paul, here's some useful information. The period of a 31 KHz square (or sine) wave is 1/31 KHz=3.226 us. So to make a 31 KHz square wave in LTspice set Tperiod=3.226us, trise=.01u, tfall=.01us, and Ton=1.6us.
#18 |
jcx,
You answer is way to complex for newbies, and not very useful. Rick |
#19 | |
There is a small typo error. 1/31 KHz should give 32.26 us Bye Gaetan |
#20 |
yes it shows some more advanced spice feautures, but I thought I was clear on how they can be copy/pasted from my post
learning how to get the Spice SW do the calculation seems worth the complication if you're using oddball frequencies with primes too big to count on fingers in their factorizations |
| LTspice square wave and audio amp test | maouna | Solid State | 2 | 11th December 2010 09:34 AM |
| Sine wave - Square & Triangle wave generator using Transistors / OP-Amps | lineup | Solid State | 20 | 9th October 2006 12:15 AM |
| 10 KHz Square wave output? | mura | Solid State | 17 | 31st May 2005 12:19 AM |
