Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
How can I do a 10 khz square wave with LtSpice ?
Old 4th August 2011, 07:26 PM   #1
tessier is offline tessier  Canada
Default How can I do a 10 khz square wave with LtSpice ?
Hi
How can I generate a 10 khz square wave with LtSpice ? (50 % duty cycle)
And how for a 31 khz square wave ?
Thanx
Paul
Old 4th August 2011, 07:29 PM   #2
sawreyrw is offline sawreyrw  United States
Use a pulsed voltage source with the correct times. Note that Trise and Tfall should not be 0.
Old 4th August 2011, 07:41 PM   #3
Hi
I don't know how to set the LtSpice pulsed voltage source for those frequency square waves.
Thanx
Paul
Old 4th August 2011, 07:53 PM   #4
ingenieus is offline ingenieus  South Africa
Add a voltage source to your circuit. Right click on it. A window like below should pop up. The values below gives a 10kHz square wave. Adjust for 31kHz.
Old 4th August 2011, 08:01 PM   #5
Hi
Is it the Tperiod or the Ncycles that I have to adjust to get 31 khz ?
Thanx
Paul
Old 4th August 2011, 08:07 PM   #6
Tekko is offline Tekko
Banned
You can leave Ncycles alone since thats only how many cycles it'll give before it stops, leaving it blank will make a continous pulse train.
On Nperiod you put in the equivalent time for 31 kHz and Ton will be half of that value to define 50% duty cycle.
Rise and fall can be set to 1.
Old 4th August 2011, 08:15 PM   #7
jaycee is offline jaycee  United Kingdom
Tperiod would be 1/31000.
Ton will be half that
You may do:
Ton = {0.5/<value in Hz>}
and
Tperiod = {1/<value in Hz>}
I would also use rise/fall times of 0.01u as this will give you a "perfect" square wave with no percievable rise/fall time.
Old 4th August 2011, 08:22 PM   #8
Hi
So, to get 31 khz, I set Tperiod to 31u and Ton 15u ?
Thanx
Paul
Old 4th August 2011, 08:42 PM   #9
jcx is offline jcx  United States
for symmetry you need to set Ton = (1/2)*(1/f) - t_rise
use curly brackets, .param to save typing
Old 4th August 2011, 08:51 PM   #10
Pano is offline Pano  United States
Pano's Avatar
Moved to Software forum
How can I do a 10 khz square wave with LtSpice ?Hide this!Advertise here!
LTspice square wave and audio amp test maouna Solid State 2 11th December 2010 10:34 AM
Sine wave - Square & Triangle wave generator using Transistors / OP-Amps lineup Solid State 20 9th October 2006 01:15 AM
10 KHz Square wave output? mura Solid State 17 31st May 2005 01:19 AM
Copyright ©1999-2017 diyAudio
