Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
NEWBIE - POWER SUPPLY SIMULATION PROBLEM
Old 26th July 2011, 09:00 PM   #1
obiwankenobi is offline obiwankenobi  Argentina
obiwankenobi's Avatar
Default NEWBIE - POWER SUPPLY SIMULATION PROBLEM
Hello friends, I am a newbie to SPICE nad Micro-Cap.
I need help with this simulation. It is about a 50V @ 10 A power supply.
The original circuit was taken from the National Semiconductor LM723 datasheet.
I added one Darlington and extra power transistors.
The problem is that before going deeper in the simulation, I can see that the D4 Zener diode shows a very high voltage of almost 80 V instead of the rated 36 V.
I tried to lower the output current and I think that leaving the CL and CS terminals of the LM723 is not a good idea for the simulation.
I searched for some specific Micro-Cap forum in Google but no luck.
What am I doing wrong ?
Thank you in advance.
Old 27th July 2011, 06:19 PM   #2
kaspich is offline kaspich  Latvia
U drop on D4 is 79.3-45.5 = 33.8V and is OK
1. replace D2 with 100ohm
2. add 1Kohm between B and E of X2
3. add 100ohm between E/X2 and CL/UA723
4. replace R1 with current source
5. replace D4 with 15..20V zener
NEWBIE - POWER SUPPLY SIMULATION PROBLEMHide this!Advertise here!
Newbie Aikido power supply question JackM11 Tubes / Valves 14 2nd August 2008 12:58 AM
Sonic Impact Power Supply-Newbie ReallyBigWoofer Class D 14 18th January 2007 07:32 PM
power supply pspice simulation problem metebalci Tubes / Valves 9 10th August 2004 02:59 PM
newbie gainclone/power supply question wotan2525 Chip Amps 7 26th February 2003 07:25 PM
Newbie circuit question - DC Adapter Power Supply Bwee Everything Else 1 8th September 2001 09:27 PM
Copyright ©1999-2017 diyAudio
