| Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators |
#11 |
because it is working and tested, havent hear the sound yet but this is a working circuit.
it came from a local audio site. here it is: http://www.electronicslab.ph/forum/i...?topic=26603.0 Last edited by carlsburg; 4th June 2011 at 01:40 AM. |
#12 |
Hi Carlsburg
I tend to agree with Bill, this is a DIY site where you will find loads of help, but NOT people willing to help those who don't or won't try. I am still learning every day as this is not my profession either, the fun is in trying or trying to find out the answers, not to join and ask others to do the work for you ![]() Try this site, I found it really easy to learn the software and now use it to design my own parts and PCB's every week. DipTrace - Professional Schematic & PCB Design Software Cheers and good luck
If you keep digging in the garden of failure you will eventually find success
#13 |
i understand you what you are saying, ok ill try to build it with the site you gave.
do i have to register first or download it without registering? thanks |
#14 |
Hi Carlsburg
Go to the download page and hit, DipTrace 2.1 Freeware All programs and all libraries. 300 pins limit, non-profit use only. This is what I use, I don't think you will hit the 300 pin limit for a while. ![]() Glad to help, shot me a message if you get stuck.
#15 |
Carlsburg- I see that your join date is very recent., Much of what you need to know to design a PC board is avaiable on this forum. Dagwood had offered one solution. There are many others. I would suggest that you read this huge forum, and learn. With all due respect
"You can keep your insurance baby nothing is guaranteed" -Tom Petty |
#16 |
i have created the board, can anybody check my work and put a ground on it.
ill gonna email it, so pls post your email. thanks |
#17 | |
There are also paid for packages which usually have better functionality than the free ones but do tend to be harder to use. A pcb package with plenty of error checking is best as one fault and the pcb needs hacking to get it going. Keep your pcb as tight as possible with thick tracks for power and you shouldnt go too far wrong.
http://www.murtonpikesystems.co.uk PCBCAD50 pcb design software. |
#18 |
hai.>>>>>
thanks fery much |
#19 | |
You really can't do complex digital projects this way but audio amps tend not to use those tiny parts. You can sketch the PCB layout right on the copper board with pencil then when you like cover the pencil lines with tape. I'd split a complex project up and use several of these PCBs. One for the power supply, one for left and right power section and so one. Easier to debug. If you are new to PCB designing then build a working power supply first. Use the vinyl tape method. maybe make a few of those, then a simple power section for an amp. Only then try something complex and maybe get into software. One other construction technique, that was used in the electronics industry before PCBs were invented is "turret boards". These are associated to vacuum tubes but only because that was the technology of the day. Turrets can support a SS design. This can be built with simple hand tools. They are easy to design too because the layout can closely resemble the schematic. It was the best available technology in the 1940's See this for more info. http://en.wikipedia.org/wiki/Turret_board Last edited by ChrisA; 17th June 2011 at 08:45 PM. |
#20 |
You dont for simple layouts.
Once there is more than say a dozen components then errors can creep in and cause all sorts of problems. There are plenty of free cad packages around now which will allow the iron on method before developing. A major advantage of pcb cad software is the error checking between sch and pcb and also for clearances etc.
| Eagle vs. Sprint-Layout for PCB design/layout | hollowman | Parts | 10 | 8th October 2012 06:13 PM |
| pcb layout | jamesrnz | Power Supplies | 0 | 9th March 2008 12:42 AM |
| About PCB layout | gaetan8888 | Solid State | 14 | 11th January 2008 04:11 AM |
| help for a PCB layout | pencoat | Parts | 0 | 4th October 2006 01:52 AM |
| Any one have Pcb layout for... | jleaman | Pass Labs | 0 | 28th July 2002 10:56 PM |
