| Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators |
Trying to do a little THD simulation with LTSpice.
Simulating Rod Elliotts P3A I get huge input sine wave THD which ofcourse screws up the whole simulation. See attached pictures. Did I overlook some obscure LTSpice setting? Last edited by Neutrality; 15th May 2011 at 12:12 PM. |
#2 |
Your .four statement is incorrect. It doesn't understand "1-khz". Try ".four 1000 9 V(input)" or ".four 1k 9 V(input)".
It'll run faster if you set the max step size to say 1u. Usually, 1/1000th the period of the input is fine. Bill |
#3 |
It works now, great.
![]() Thanks alot for the help. ![]() But as the picture shows, at 1kHz, 50W into 8 ohm load the THD is above 0.1%. And at the same power into the same load but at 20kHz the THD is 1.3% ![]() Would like to get atleast the 1kHz THD below 0.01 if possible and the 20kHz THD below 0.1 But now I can get started.
#4 |
A good start would be setting the output stage idling current. The ratio of R7 to R9 looks wrong, IMO.
#5 |
#6 |
Well after reducing R7 to 450 Ohm, which gives an output stage idle current of about 60-65 mA THD-20 at 50 W into a 8 Ohm load is now down to 0.8%.
Better but not perfect, however the THD-1 should be a good deal better as well. And indeed it is, THD-1 at 50 W into a 8 Ohm load is now down to 0.08%. Last edited by Neutrality; 15th May 2011 at 02:21 PM. |
#7 |
An interesting thing is that eventhough Rod Elliott advises to use between 20-100mA idle current for the output stage a simulation with even higher idle current shows a definate improvement.
250mA output stage idle current gets THD-20 numbers of around 0.65% at the same 50 W in to an 8 Ohm load. Guess going higher than recommended is a good thing, as long as you have enough heatsinking. |
#8 |
Yes, in many cases, higher idle current will yield less distortion - until the peaks get to the top of the linear part of the transfer function (i.e. clipping), and then things get nasty real fast.
Bill |
#9 |
Self, Cordell's amplifier design books are a big help learning how to reduce distortions
currrent mirror load in the diff pair collectors equalizes diff pair current for less input stage distortion - the 1st step I'd take since increased loop gain is less useful if the diff pair can't accurately measure the error V to apply negative feedback two more steps "beta enhanced " VAS - a ef buffer between the diff pair out and the VAS Q with Cdom enclosing both and a ef buffer btween the VAS out and the (compound) output Q - for a total of 3 Q giving current gain after the VAS I have posted a Ltspice version of one of Bob Cordell's book's example circuits to explore stability/compensation in Bob Cordell's Power amplifier book (my stability example circuit derived from Bob's posted asc Bob Cordell's Power amplifier book post 1184) this uses all 3 tricks suggested but with straight "triple" ef/darlington output, just rearanging the last 2 output Q for your CFP and adjusting bias should be quick Last edited by jcx; 17th May 2011 at 03:17 AM. |
| High frequency sine wave on the LM1036 output | daniel23 | Chip Amps | 37 | 22nd November 2011 12:13 PM |
| Sine Wave Generator with bulbs (Sine-lightenment) | Rodeodave | Everything Else | 6 | 21st July 2008 12:19 PM |
| Sine wave - Square & Triangle wave generator using Transistors / OP-Amps | lineup | Solid State | 20 | 9th October 2006 12:15 AM |
| Page generated in 0.11362 seconds (76.11% PHP - 23.89% MySQL) with 11 queries |
