Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
ARTA analysis SW and LTspice under OSX on a hackintosh
Old 8th May 2011, 08:52 AM   #11
triode_al is offline triode_al  Netherlands
triode_al's Avatar
Hi Richiem,
sorry to bother you,
I have yesterday installed Crossover/Wine on my iMac, downloaded the LtSpice IV too,
+ it opens a diagram
+ it allows me to make my own schema
but I did run into some significant problems:
- cannot find out how to rotate a component like a zener, that is awkward.
- can't open the help file (LTspiceHelp.chm), the iMac knows nonesuch extension
- can't get data in the components (like set the voltage for a power input), the field will not edit, and I then get a dump (in Dutch):
Maybe you have some special tricks?
albert
SPU --> tube MM/RIAA; Kaneda pre; 300B SE driven by ECC35; Open Baffle PM2A, 2A9
Old 8th May 2011, 10:13 AM   #12
triode_al's Avatar
I have downloaded CHMOX, to open LTspiceHelp.chm
This gave me the necessary insight, it is now up & running.
Couldn't take out my post anymore
albert
Old 8th May 2011, 08:19 PM   #13
richiem is offline richiem  United States
richiem's Avatar
@ triode_al -- good job on getting up and running. I found that getting to a place where I could actually use LTspice was really painful, since I had never used any Spice program at all. There are still things that can be done that I don't know how to do -- e.g. making a pin label like "+V" that refers to a power source connection, so that you don't have to run supply leads all over the diagram. The help files don't really help with that. And I find importing models confusing and time-consuming, and they often don't work like I want them to. But it works. Poco a poco.
Old 8th May 2011, 08:52 PM   #14
triode_al's Avatar
Hi Richiem,
I saw there is a Yahoo group devoted to LT Spice, there must be more info around there, some real developers are supporting it.
But it is not poco a poco, it is a lot of dedicated information at once then
Anyway, you triggered me to this so thanks!
albert
ARTA analysis SW and LTspice under OSX on a hackintoshHide this!Advertise here!
A note about ARTA audio analysis software richiem Software Tools 48 2nd June 2016 05:52 PM
ARTA - using ARTA to measure room acoustics! OMF Software Tools 0 25th November 2009 01:55 PM
How to make sense of LTSpice FFT analysis? ray_moth Software Tools 11 12th August 2008 07:43 PM
Gerber help on Mac OSX pinkmouse Everything Else 4 3rd May 2005 02:38 PM
OSX Server HELP!! jleaman Everything Else 9 10th September 2003 08:30 AM
Copyright ©1999-2017 diyAudio
