| Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators |
Hello,
I just made a simple SPICE simulation with an op-amp and virtual ground (read: single supply). However it doesn't seem to work. The output of the op-amp gets distorted and inverted for some unknown reason to me. Have I made some fundamental error in the circuit or is SPICE just kidding with me? ![]()
#2 |
The circuit should provide an amplifier output, but the input needs to be "centered" at 6 volts. The equivalent circuit to the left of R2 is 6 volts in series with 2.35k. The gain is 1+10k/(1K+2.35k) and the output will be 6 volts when the input is 6 volts. Do you have the input centered at 6 volts?
#3 | |
#4 |
What is the voltage on the positive input? AC component and DC component?
#5 |
#6 |
Try biasing the + input to 6 volts too.
#7 |
#8 |
Your virtual ground should be the node at were r3 and r4 are connected. jer
#9 |
Dont know the software your using. Try adding a dc offset to the signal generator.
#10 |
#7
diyAudio Member Join Date: May 2010 Quote: Originally Posted by cbdb Try biasing the + input to 6 volts too. How do I do that? by putting a resistor from the node of r3 and r4 to the +input on the opamp. And disconnect r2 from the same node and it should work (i hope). jer Last edited by geraldfryjr; 28th March 2011 at 09:31 PM. |
| Virtual ground in power amp applications | aspringv | Power Supplies | 44 | 23rd September 2011 01:31 PM |
| Creating the 'virtual ground' in a single supply preamp/amp circuit??? | DoiNk! | Solid State | 9 | 9th April 2011 05:19 PM |
| Virtual Ground ? | Bernhard | Solid State | 13 | 4th March 2009 01:57 PM |
| Decoupling cap placement - virtual ground dual op amp? | Triophile | Solid State | 1 | 27th March 2006 06:30 AM |
| virtual ground...help | jsteigs | Chip Amps | 6 | 3rd February 2005 10:49 AM |
| Page generated in 0.11343 seconds (79.63% PHP - 20.37% MySQL) with 11 queries |
