Go Back   Home > Forums > Design & Build > Software Tools
Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
Old 5th March 2011, 09:26 PM   #1
fhs is offline fhs  Germany
fhs's Avatar
Default 6S4/6S4A TINA-TI/SPICE model?
I am fully aware that I am not the first person asking about a SPICE model for the 6S4(A) triode... Maybe in the meantime some expert has managed to put such a model together and would like to share it here? I'd be delighted!
Thanks and best regards,
Fred
Old 11th March 2011, 06:12 PM   #2
fhs's Avatar
since there was no reply to my inquiry I had to come up with my own solution. Norman Koren was so kind as to run parameters I had extracted from the datasheet through his Tuparam software. The resultant model needed some tweaking, for which I used James E. Lanier's program PSPICE_Calc . The match is not perfect, but approximates the normal operating range (Ug=[-8v..-12V]) reasonably well:
The thick lines are the ones from the datasheet, the thin ones show what the model parameters do.
I plugged these data into a TINA-TI model and created a TINA macro for it.
Code:
*TEXAS
.SUBCKT 6S4A P G C ; P G C
+ PARAMS: MU= 16.5 EX= 1.344 KG1= 1090 KP=133
+ KVB= 4.5 VCT=0.00 RGI=1000
+ CCG=4.9p CGP=2.9p CCP=1.1p ; .7PF added to adj. pins, .5 to others
E1 7 0 VALUE=
+{V(P,C)/KP*LOG(1+EXP(KP*(1/MU+V(G,C)/SQRT(KVB+V(P,C)*V(P,C)))))}
RE1 7 0 1G
G1 P C VALUE={(PWR(V(7),EX)+PWRS(V(7),EX))/KG1}
RCP P C 1G ; TO AVOID FLOATING NODES IN MU-FOLLOWER
C1 G C {CCG} ; CATHODE-GRID
C2 G P {CGP} ; GRID-PLATE
C3 P C {CCP} ; CATHODE-PLATE
D3 5 C DX ; FOR GRID CURRENT
R1 G 5 {RGI} ; FOR GRID CURRENT
.MODEL DX D(IS=1N RS=1 CJO=10PF TT=1N)
.ENDS
And here is the test run under TINA-TI:
Again, this will require more work, but it is a start. Thanks again to Norman and James without whose software I would not have tackled this project.
Fred
Old 16th March 2011, 05:38 PM   #3
fhs's Avatar
Amended model (better match for -12>Ug>-28V):
And here is the TINA-TI model:
Code:
*TEXAS
+ PARAMS: MU= 17.18 EX= 1.267 KG1= 873.1 KP=105.3
+ KVB= 31.7 VCT=0.00 RGI=1000
E1 7 0 VALUE=
RE1 7 0 1G
.ENDS
Old 17th March 2011, 01:07 AM   #4
ywara is offline ywara  United States
You might want to try:
ex = 1.406
kg1 = 988.4
kp = 76.5
kvb = 16.53
mu = 18.62
I get an RMSE of ~7.1e-4 and the curves have a slightly better visual match.
Old 17th March 2011, 07:54 AM   #5
fhs's Avatar
thank you, ywara. I agree that the curves look more closely matched with your parameters:
Warm regards,
Fred
Old 9th December 2011, 04:23 PM   #6
Pryanick's Avatar
Send a message via ICQ to Pryanick
Hi P!PL
I try TINA-TI now and I need *.CIR files for tubes
If you have some CIR-files for tubes could you upload it here?
I need 6N1P, 6N2P, 6N9S, 6N23P, 6N24P and for other tubes.
It would be very nice...
THX
Old 9th December 2011, 05:34 PM   #7
fhs's Avatar
Hi Pryanick,
here are two sites to get you started:
Improved vacuum tube models for SPICE, Part 1
Spice Models
Most models you find browsing the net were made for SPICE and do not necessarily work with TINA-TI. Just insert "*TEXAS" as the first line and see if you can make them work...
BTW: Nice avatar!
Warm regards,
Fred
Old 9th December 2011, 08:04 PM   #8
Pryanick's Avatar
Thank you for help, Fred
I found almost all i need and that is perfect!
P.S.: I sent you complement for my avatar to my female cat - and she liked it!
Keep your iron solder hot
Old 9th December 2011, 08:35 PM   #9
fhs's Avatar
My pleasure, Pryanick. Warm regards to you and your cat from myself and from my tomcat. Hope your projects are enjoyable and turn out well.
Old 2nd January 2012, 03:52 PM   #10
hi! i am a beginner and i have ecc 85 and try to build preamp for MM and need shematic vith good performance. p.s. sory for my poor enlish
ECC88 symbol problem in TINA-TI Tauri Tubes / Valves 5 5th November 2010 12:52 PM
TINA-TI Tube Simulation windwood Tubes / Valves 12 9th April 2010 09:21 PM
TI Tina ctardi Chip Amps 5 17th January 2010 12:47 PM
Simulation Models for OPA827 and TINA-TI stef1777 Parts 8 13th March 2008 04:56 AM
free Tina ti circuit sim for crossover design sreten Multi-Way 2 1st February 2006 11:10 PM
Page generated in 0.10375 seconds (80.23% PHP - 19.77% MySQL) with 11 queries
