| Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators |
Im having an issue with gerber files generated from Eagle.
Looking at the gerbers with viewplot and everything is okay, except some of the drill holes arent present, on the polarized caps, some of the transistors and the big input film cap. Whats up with that? and how do I fix it? Note : Im using the standard libraries that comes with Eagle so that shouldnt be an issue. Ran drillcfg.ulp, create excellon drill files from the .drl file with excellon.cam and then I created the gerber files with gerb274x.cam. Last edited by Neutrality; 19th February 2011 at 08:36 PM. |
#2 |
Drill files don't show on Gerbers, they are an entirely separate process.
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#3 |
Hi Neutrality,
I use gerbv and I need to have the drill file at the top of the file list so it appears over the top of traces and pads. Still does not explain why some show and others don't. If you want to email your pcb file I can have a closer look. regards
Greg Erskine |
#4 |
Thats a serious bug and I thought Eagle was quite a mature package.
I would get in touch with them and see what they say, there might be a software patch out for it.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software. |
#5 |
What are you talking about?
Greg Erskine |
#6 |
The holes missing off his pcb ?
#7 |
I doubt the holes are actually missing in Eagle. Either the gerbers have not been created properly (extra layer included), the gerber viewer has an issue or maybe a minor operator error. The gerber viewer is not part of Eagle.
Greg Erskine |
#8 |
I have no problem with drills on eagle.
To see the drills corectly you will need the right file to be read by gerbv. The file has extension *.txt , You can get 2 or more drill files as the manufactures needs. Maybe you have to check again your cam generator settings. |
#9 |
Are the files standard excellon or extended excellon?
Extended excellon is similar to RS273X in that it will generate its own tool table, whereas standard excellon you have to create a drill table or it will ignore the holes. Extended excellon look similar to: M48 METRIC,TZ T01C.25 T02C.45 T03C1.4 T04C3.5 ;LEADER: 12 ;HEADER: ;CODE : ASCII ;FILE : 8000068B-1-8.drl for board 8000068B.brd ... layers TOP and BOTTOM ;T01 Holesize 1. = 0.250000 Tolerance = +0.000000/-0.000000 PLATED MM Quantity = 1026 ;T02 Holesize 2. = 0.450000 Tolerance = +0.000000/-0.000000 PLATED MM Quantity = 143 % G90 T01 X265000Y-52500 X475000Y-52500 X530000Y-52500 X575000Y-52500 Myself, I dont use Gerbers and Excellon any more as its old fashioned and can be a total pain, ODB++ is a much better format, less prone to errors and more manufacturer friendly. I dont know whether Eagle caters for this format, as I use Cadstar. |
#10 |
Like I said, I created a .drl file, made the Excellon file with that and then made the gerbers.
But some of the holes dont show, tried it a few times, same result. Weird. Going to use makepcb.com, following their guide right here : http://makepcb.com/media/convert%20e...er%20files.pdf Last edited by Neutrality; 20th February 2011 at 10:46 AM. |
| Eagle won't change drill sizes! And double sided boards... | cuibono | Everything Else | 1 | 21st November 2007 11:52 PM |
| BPA300 Eagle File .BRD - No Catches | DJ Exprice | Chip Amps | 414 | 12th July 2007 03:46 AM |
| LM3886 Eagle file | Adam M. | Chip Amps | 3 | 15th August 2004 02:16 AM |
| LM4780 .lbr file for Eagle | Alcaid | Parts | 2 | 26th March 2004 06:22 AM |
| Drill files in eagle??? | bigparsnip | Parts | 1 | 4th March 2004 01:02 PM |
| Page generated in 0.17009 seconds (36.95% PHP - 63.05% MySQL) with 12 queries |
