Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
simulating "Deep Frame Dipoe" (DFD) Woofers, AkAbak?
Old 22nd December 2010, 07:06 PM   #11
mige0 is offline mige0  Austria
mige0's Avatar
Location: Austria, at a beautiful place right in the heart of the Alps.
Soho54,
I gave the dual chassis N-frame a try.
this is how it measures (red trace) directly at mouth:
Could you have a look if code is ok so far?
I switched / simplified to „dEdge=1mm“ as I found this in the manual to force Akabak to do diffraction calculation as well.
What I'm not really happy with, is to use a „duct“ for the closed end piece.“Waveguide“ seems not to allow for closing one end with a „0-node“ ??
Any suggestions?
Code:
System 'N2-Frame'
Def_Driver  '15PW5'
  dD=33cm   |Piston
  fs=40Hz  Mms=84.6g  Qms=16.8
  Qes=0.41  Re=5.5ohm  Le=1mH
Driver Def='15PW5''Driver'
  Node=1=0=2=3
  Node=1=0=200=300
Duct    'DU-r'  Node=200=0
  dD=10cm  Len=20cm
Waveguide    'Rear1'  Node=200=2
  dTh=10cm  dMo=30cm
  Len=40cm  Conical
Waveguide    'Rear'  Node=2=22
  dTh=30cm  dMo=45cm
  Len=20cm  Conical
Radiator  'Rear Outlet'  Def='Rear'
  Node=22
  x=0  y=0  z=-40cm  HAngle=180  VAngle=0
  dEdge=1mm
  Label=2
Duct    'DU-f'  Node=300=0
  dD=10cm  Len=20cm
Waveguide    'Front1'  Node=300=3
  dTh=10cm  dMo=30cm
  Len=40cm  Conical
Waveguide    'Front'  Node=3=33
  dTh=30cm  dMo=45cm
  Len=20cm  Conical
Radiator  'Front Outlet'  Def='Front'
  Node=33
  x=0  y=0  z=40cm  HAngle=0  VAngle=0
  dEdge=1mm
  Label=1
here is the simulation result of above code at 1m mic distance:
Quite some room for improvement I'd say - but - at least the deep null seems to be at the right place - as seems to be the up-shift of the first peak captured - as seems the SPL increase at the bottom end to be captured..
Michael
Old 22nd December 2010, 07:48 PM   #12
mige0's Avatar
Originally Posted by mige0 View Post
Soho54,
Composed the conical end piece out of „waveguide“ and „duct“
Code:
System 'N2-Frame'
|-------------- driver ----------------
Def_Driver  '15PW5'
  dD=33cm   |Piston
  Node=1=0=2=3
  Node=1=0=200=300
|-------------- end driver ----------------
|-------------- rear firing pipe ----------------
Duct    'DU-r'  Node=201=0
  dD=1cm  Len=1cm
Waveguide    'Rear2'  Node=201=200
  dTh=1cm  dMo=10cm
  Len=19cm  Conical
  dTh=10cm  dMo=30cm
  Len=40cm  Conical
  dTh=30cm  dMo=45cm
  Len=20cm  Conical
  Node=22
  dEdge=1mm
  Label=2
|-------------- end rear firing pipe ----------------
|-------------- front firing pipe ----------------
Duct    'DU-f'  Node=301=0
  dD=1cm  Len=1cm
Waveguide    'Front2'  Node=301=300
  dTh=1cm  dMo=10cm
  Len=19cm  Conical
  dTh=10cm  dMo=30cm
  Len=40cm  Conical
  dTh=30cm  dMo=45cm
  Len=20cm  Conical
  Node=33
  dEdge=1mm
  Label=1
|-------------- end front firing pipe ----------------
Slightly more elegant this way, though the deep null seems to be less correct
Michael
Old 22nd December 2010, 09:36 PM   #13
soho54 is offline soho54  United States
Another problem I've come across - seems if I simu close to mouth - approaching 40cm in above example - SPL level sky rocks to several 100dB. Any idea?
AkAbak doesn't like the listening point to be inside the model. You will also find that you have to place it a bit back from the Radiator as well do to the end correction it adds.
Why writing:
Node=1=0=2=3
and not :
Driver Def='15PW5'
Node=1=0=2=3
is there a difference?
The 'Driver' added is the name of the component. I just didn't feel very creative. You don't have to add it. It helps more with multi driver scripts when you are checking out different graphs.
Old 22nd December 2010, 11:47 PM   #14
You don't have to ground the end of a waveguide really.
This is how I would start off. Note that when you start using Waveguides you have to have more exact placements.
Here is a guesstimate.
Code:
System 'N2-Frame'
Def_Driver  '15PW5'
  dD=33cm   |Piston
Driver Def='15PW5''Driver 1'
  Node=1=0=44=3
Driver Def='15PW5''Driver 2'
  Node=0=1=4=33
Waveguide    'Rear A'  Node=22=33
  WTh=5mm  HTh=36.4cm  WMo=8.4cm  HMo=36.4cm
  Len=18.2cm
Waveguide    'Rear B'  Node=33=44
  WTh=8.4cm  HTh=36.4cm  WMo=26.6cm  HMo=36.4cm
  Len=39.3cm
Waveguide    'Rear C'  Node=44=55
  WTh=26.6cm  HTh=36.4cm  WMo=36.4cm  HMo=36.4cm
  Len=21.5cm
Radiator  'Rear Outlet'  Def='Rear C'
  Node=55
  WEdge=40cm HEdge=40cm
  Label=2
Waveguide    'Front A'  Node=2=3
  Len=18.2cm
Waveguide    'Front B'  Node=3=4
  Len=39.3cm
Waveguide    'Front C'  Node=4=5
  Len=21.5cm
Radiator  'Front Outlet'  Def='Front C'
  Node=5
  Label=1
Old 26th December 2010, 07:12 PM   #15
mige0's Avatar
Thanks soho54
good hint regarding theres no need for closing a WG.
Your code sim's like that:
not that bad - but - what you think could achieve even better correlation to measurements?
I messed around with the idea of distributing the 15" chassis into a hex arrangement to come closer (in simulation !) to the fact that the 15"ers actually do *not* radiate into the wave guide at *exactly* one point only.
This "distributed" radiation into the WG must IMO result in a strong FR difference, as "resonance modes" are excited in a pretty different manner that way.
Simu I got - sadly - are even less "the real thing":
Peaking is way too hot and not a t the right place as well - also deep null (400-500Hz) filled too much
here is the code I used:
Code:
System 'N2-Frame' | N-frame Deep Frame Dipole  / outer dimension 40x40x80cm / 2x15" arranged distributed in "hex+centre"
Def_Driver  '15PW5'
  dD=12.5cm   |Piston
Driver Def='15PW5''Driver 1_1'		| "distributed" driver "hex+centre"  arrangement
  Node=0=1=310=201
Driver Def='15PW5''Driver 1_2'
  Node=0=1=309=202
Driver Def='15PW5''Driver 1_3'
  Node=0=1=309=202
Driver Def='15PW5''Driver 1_4'
  Node=0=1=308=203
Driver Def='15PW5''Driver 1_5'
  Node=0=1=307=204
Driver Def='15PW5''Driver 1_6'
  Node=0=1=307=204
Driver Def='15PW5''Driver 1_7'
  Node=0=1=306=205
Driver Def='15PW5''Driver 2_1'		| "distributed" driver "hex+centre"  arrangement
  Node=1=0=206=305
Driver Def='15PW5''Driver 2_2'
  Node=1=0=207=304
Driver Def='15PW5''Driver 2_3'
  Node=1=0=207=304
Driver Def='15PW5''Driver 2_4'
  Node=1=0=208=303
Driver Def='15PW5''Driver 2_5'
  Node=1=0=209=302
Driver Def='15PW5''Driver 2_6'
  Node=1=0=209=302
Driver Def='15PW5''Driver 2_7'
  Node=1=0=210=301
Waveguide    'Front A'  Node=211=210
  WTh=1mm  HTh=40cm  WMo=2cm  HMo=40cm
  Len=4cm  Conical
Waveguide    'Front B1'  Node=210=209
  WTh=2cm  HTh=40cm  WMo=6cm  HMo=40cm
  Len=8cm  Conical
Waveguide    'Front B2' Node=209=208
  WTh=6cm  HTh=40cm  WMo=10cm  HMo=40cm
  Len=8cm  Conical
Waveguide    'Front B3'  Node=208=207
  WTh=10cm  HTh=40cm  WMo=14cm  HMo=40cm
  Len=8cm  Conical
Waveguide    'Front B4'  Node=207=206
  WTh=14cm  HTh=40cm  WMo=18cm  HMo=40cm
  Len=8cm  Conical
Waveguide    'Front C'  Node=206=205
  WTh=18cm  HTh=40cm  WMo=22cm  HMo=40cm
  Len=8cm  Conical
Waveguide    'Front D1'  Node=205=204
  WTh=22cm  HTh=40cm  WMo=26cm  HMo=40cm
  Len=8cm  Conical
Waveguide    'Front D2'  Node=204=203
  WTh=26cm  HTh=40cm  WMo=30cm  HMo=40cm
  Len=8cm  Conical
Waveguide    'Front D3'  Node=203=202
  WTh=30cm  HTh=40cm  WMo=34cm  HMo=40cm
  Len=8cm  Conical
Waveguide    'Front D4'  Node=202=201
  WTh=34cm  HTh=40cm  WMo=38cm  HMo=40cm
  Len=8cm  Conical
Waveguide    'Front E'  Node=201=200
  WTh=38cm  HTh=40cm  WMo=40cm  HMo=40cm
  Len=4cm  Conical
Radiator  'Front Outlet'  Def='Front E'
  Node=200
  dEdge=1mm
  Label=1
Waveguide    'Rear A'  Node=311=310
  Len=4cm  Conical
Waveguide    'Rear B1'  Node=310=309
  Len=8cm  Conical
Waveguide    'Rear B2'  Node=309=308
  Len=8cm  Conical
Waveguide    'Rear B3'  Node=308=307
  Len=8cm  Conical
Waveguide    'Rear B4'  Node=307=306
  Len=8cm  Conical
Waveguide    'Rear C'  Node=306=305
  Len=8cm  Conical
Waveguide    'Rear D1'  Node=305=304
  Len=8cm  Conical
Waveguide    'Rear D2'  Node=304=303
  Len=8cm  Conical
Waveguide    'Rear D3'  Node=303=302
  Len=8cm  Conical
Waveguide    'Rear D4'  Node=302=301
  Len=8cm  Conical
Waveguide    'Rear E'  Node=301=300
  Len=4cm  Conical
Radiator  'Rear Outlet'  Def='Rear E'
  Node=300
  dEdge=1mm
  Label=2
Measurement at mouth (red trace)
Michael
Old 26th December 2010, 07:32 PM   #16
mige0's Avatar
Ahh - here is the plot (two 15" *not* "distributed") with only the front radiator active to allow for tighter conditions of measurement versus simu:
The upper part of bandwidth (till 300Hz) is not bad - but the the low frequency slope comes in too high - at roughly 90Hz instead of around 40-50Hz
Michael
Old 26th December 2010, 07:42 PM   #17
mige0's Avatar
Ahh - here is the plot (two 15" *not* "distributed") with the rear radiator having "edge / diffraction" feature disabled:
The low frequency slope is where it should be (no more closed volume like in my previous post) but upper part (till 300Hz) is not "as expected" - not at all
Michael
Old 28th December 2010, 04:41 PM   #18
In the pic of my sim, we seem to be looking at the whole system. I would stick with Label 1 to compare to your measurements.
Once you start using waveguides placement is paramount. I just guessed at some simple figures for the enclosure and driver placements, so there is an error factor right there.
The other problem comes from using a waveguide in a sim. The sim only calculates the waveguides contribution, and not the extra direct sound from the woofer. It is the same condition that produces the early roll-off up top in a mid-horn sims, and the "hybrid" horn roll-off down low.
I have a couple of ideas on how to get around it, but I haven't had time to play with it yet.
Old 28th December 2010, 04:56 PM   #19
mige0's Avatar
Yeah we can try...
I have tried to bring the rear radiating SPL contribution out of picture by:
- adding a quasi IB (short but very wide WaveGuide) to the rear outlet
- setting the distance for the rear outlet way back (some -10m)
Both attempts actually did not work, so, I'm a little bit lost to which point AkAbak sims correctly regarding edge / 180deg diffraction - besides all quirks with the "distributed speaker" alignment in the pipe.
Michael
Old 29th December 2010, 04:00 AM   #20
All you have to do is use the Labels section in the SPL simulation setup screen.
If you check a box the graph will only be from the output Label you picked. If you pick Label 1 you will only get the output from the forward opening. If you pick Label 2 you get just the rear. Selecting All or N2-Frame you get the combination of both sides.
Just selecting Label 1 is like getting a near field measurement. This is how you get around the program going a little nuts from having the listening position to close to it, and the SPL shooting way up.
Either way this is still only going to show the waveguides contribution, when in this case you have to combine the waveguides output with the traditional IB output as well.
simulating "Deep Frame Dipoe" (DFD) Woofers, AkAbak?Hide this!Advertise here!
FS: BG Neo3 PDR - Special OEM "Deep-Back" Version mac Swap Meet 4 16th December 2015 05:17 AM
Suggestion for 10" woofers for U-frame dipole dabbler Multi-Way 35 6th August 2010 01:46 AM
Wanted to Buy: Pairs of 5-1/2";6-1/2";8";10" Seas Aluminum Woofers dtm1962 Swap Meet 0 15th January 2010 04:38 PM
Driver in deep baffle"tunnel" marcus1 Multi-Way 4 6th December 2009 07:18 PM
4 Fane Studio 15B 15" cast-frame woofers... tweakk Swap Meet 1 5th February 2009 02:59 PM
