Go Back   Home > Forums > Design & Build > Software Tools
Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
Old 9th November 2010, 05:02 PM   #1
Default Golden Ratio <=> Volume Calculator
Wasn't sure where to post this spreadsheet tool for calculating golden ratio and volume.
golden ratio.zip
Enter value in yellow field and it calculates white fields.
Old 9th November 2010, 10:36 PM   #2
Crap, my gf messed up the spreadsheet, fixing it.
Old 10th November 2010, 12:57 AM   #3
Corrected file.
golden ratio.zip
Old 10th November 2010, 03:22 AM   #4
frugal-phile(tm)
planet10's Avatar
From just the screenshot, you'd be better/more elegant to set your constants across the top to 0.618, 1, 1.618, 1. (ie 1/GR, 1, GR, V=1)
Since most boxes start with volume then dimensions = (cube root V)/GR, (cube root V), (cube root V)*GR.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 15th November 2010, 06:47 PM   #5
How's that then? Wish I could figure out how to do it in one line.
golden ratio.zip
Old 15th November 2010, 07:20 PM   #6
frugal-phile(tm)
planet10's Avatar
The image looks good. The Zip didn't keep the package togther thou (so is a useless mess). You should save out as a pre-xml Excel file so that it is more compatiable
Excel sucks as a spreadsheet (a good example of how world dominance stifles innovation). It should be possible to put it on 1 visible line (but would likely require some temporary cells elsewhere)
dave
Old 15th November 2010, 07:55 PM   #7
Might be because I'm using Open Office. Tried saving it as xls 'Excel 2003' this time.
golden ratio.zip
Edit. OK, maybe 7zip is at fault here. Corrupting its archives
I checked the earlier files I uploaded, they are not corrupt. Its a problem with the open office calc / m$ office excel format conversion.
Old 15th November 2010, 08:49 PM   #8
frugal-phile(tm)
planet10's Avatar
Just double clicking it opens it in Illustrator as a text file. When i opened it in Excel (2004) all the formulas were gone.
I redid it for you, here saved as Excel 2004 WorkBook. If anyone needs older format ask
dave
Old 15th November 2010, 10:04 PM   #9
Gee, thanks Mister!
Formulas I used are a little different.. Columns B-E, Rows 3-6
B3 [=E3^(1/3)/D2], C3 [=E3^(1/3)], D3 [=E3^(1/3)*D2], E3 [Blank-Enter Volume]
B4 [=D4/D2/D2], C4 [=D4/D2], D4 [Blank-Enter Height], E4 [=B4*C4*D4]
B5 [=C5/D2], C5 [Blank-Enter Length], D5 [=C5*D2], E5 [=B5*C5*D5]
B6 [Blank-Enter Width], C6 [=B6*D2], D6 [=C6*D2], E6 [=B6*C6*D6]
Circuit Maker <<questions>> bogdan_borko Solid State 23 24th January 2011 10:31 AM
>>> Project Floorstanding Cabinet Wanted <<< presscot Multi-Way 2 28th July 2010 12:20 AM
> Audio <> music <> quick <> synergy <> angst>? rick57 Everything Else 0 4th May 2007 04:03 PM
guitar<--->???<--->chipamp ultrachrome Instruments and Amps 3 2nd November 2005 03:56 AM
Golden ratio - Example? icebear Multi-Way 5 17th April 2004 08:40 PM
Page generated in 0.11875 seconds (77.00% PHP - 23.00% MySQL) with 11 queries
