Go Back   Home > Forums > Design & Build > Software Tools
Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
Old 23rd October 2011, 08:37 AM   #61
gmant123's Avatar
Default 2011 software
Hello all:
Has anyone tried the new software, or other circuits proposed?
Thanks.
Alberto.
Old 16th February 2012, 01:20 PM   #62
Are there any good guides about the hardware in english?
Are the simple curcuit here: ZRLC adequate for accurate measurements?
Old 16th February 2012, 02:55 PM   #63
Default Have you read something at all in this thread?
Hi MagPal
Everything is in this thread. It's actually pretty good.
Read my simple guide in English which is attached in post #58.
Cheers// Ove
Old 16th February 2012, 07:25 PM   #64
Allright. hard to fully understand the PDF without understanding the language. Will the schematic on page 10 do the job?
A couple of questions:
-Rtest are not specified. Do this have any function?
-Should the resistor switch be connected in paralell og instead of the 10k resistor?
Or do the schematic on page 9 do the job correctly? (Just replace the 10k with a resistor-switch) The only difference seems to be the Rtest and the paralell connection with the switch. +the USB powersupply.
Old 14th May 2012, 12:09 AM   #65
hotiron is offline hotiron  Scotland
hotiron's Avatar
This schematic on here (See link) works great. I've been having fun with this tonight ,works great, pretty accurate and its only built on a solderless breadboard with wires everywhere.
Have to give a great big thank you to Alfredo Accattati, as this is one great bit of software
ZRLC
If you give up easily Dont start!!
Old 30th May 2012, 10:24 PM   #66
I bought the dedicated hardware from the Italian magazine and I have a few questions for someone who used VA for ZLCR testing. I managed to understand several things from the Italian articles, basically that the ranges are correct only at 1KHz and at other freq. they are not and this is not represented in the software. I have inductors and capacitors which I would like to sweep through from 20Hz to 20KHz. I take 100 points and the readings are stable, however when I try to scan large spans the application will throw an exception. I tried using 2010,11 & 12 and sweeping does not work at all in 2012. I have a cheap DMM with inductance meter and for a specific inductor is reads about 250mH and from the DVM spec. the reading is at 270Hz. I can never get the same reading on the ZRLC meter and I get 300+mH. I don't know who to believe. Did anyone manage to get this thing working reliably and using sweeps?
This is an example of an L sweep I was able to perform using range 4. Most of data is good but you can see there are points that doesn't line up. I would like to solve that somehow.
Old 3rd June 2012, 12:18 PM   #67
So I was running more tests and I am afraid to say that the results are very poor. I can not get accurate results on anything including SMD resistors which should be pretty accurate. I have the hardware from the Italian magazine. Any idea what could be wrong is the software that throws the readings that much off?
how to make this esr meter work with 250uA Panel meter dytln_02 Everything Else 2 27th January 2007 10:13 PM
inductance meter from a cheap meter? jarthel Parts 3 22nd September 2006 05:37 AM
Making a milliAmp meter, become a Volt meter redrabbit Power Supplies 11 26th May 2006 07:51 PM
t-amp vu meter and volt meter question.... rectaacies Class D 7 3rd February 2006 11:22 AM
Copyright ©1999-2013 diyAudio
