Go Back   Home > Forums > Design & Build > Software Tools
Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
Old 10th September 2010, 10:26 PM   #11
Elvee
You refer to .. as it seems interresting links but the languish problem persist. I will try with google translate and let you know if I went happy about the information
je suis a room avec douche silvoplait
Have fun!
Cheers// Ove
Old 11th September 2010, 06:58 AM   #12
Elvee is offline Elvee  Belgium
Elvee's Avatar
Sorry, I have no idea about the identity of your guy at MW.
For the projects, the text is in french, but schematics and pictures are universal. Of course, there is always the risk to miss a small detail, just as I did.
Old 11th September 2010, 06:10 PM   #13
zdr is offline zdr  Belgium
zdr's Avatar
I build mine with Lm833 (burnt my only lm358 as there is a blunt error in ps polarity on the web page), and finally made it work, running on single 9V PS with virtual ground. I have ridiculous errors of around 20-50% at 1KHz, for 100ohm range (0.82mH reported as 0.99, 3.9 ohm as 5.6, etc). Some serious issues with app not entering calibration mode, then getting stuck in calibration mode, and so on...
Starting to remind me of speaker workshop on which I wasted a good week before I threw it away together with it's jig.
I hope I am missing something as usual What do you guys use as PS? Which version you built?
Old 11th September 2010, 06:28 PM   #14
zdr's Avatar
Actually, I swapped back my supposedly dead LM358, and guess what - not only that is not dead, but also measured my 0.82mH coil as 0.8224mH I guess we all better stick with the recipe and use LM358 as specified by author. Digits are also quite calm... Back to more testin'
Old 11th September 2010, 06:58 PM   #15
Elvee's Avatar
In this case, I think i'll give a try to a LM324, instead of the TL074.
For 1KHz, anyway, shouldn't change anything.
With a high averaging value, it's OK for the main parameter, but the minor parameters are not filtered, and a good hardware stability would certainly be helpful.
Old 12th September 2010, 09:51 PM   #16
zdr's Avatar
I just could not make it work properly with my SB Audigy, running on KX Drivers. It was off 4 times just by switching range... But, with built in SoundMax, works like a charm, quite consistent. If I measure 3.3uF with 100 ohm then switch to 1000 ohm with same DUT, it's off by 0.02uF; but, that could be due to measurement resistor tolerance, so I ordered some 0.01% resistors to replace 1% ones. I wonder how much they influence overall accuracy...
I cannot compare to any stock meter, but it seems to be quite accurate. Finally a good, working and cheap LCR meter
Old 12th September 2010, 10:50 PM   #17
Must be lots of interest in this one. The site was quite slow a while ago.
I slapped together an L meter for speaker range inductances. Not nearly the same league as this, but it fits in a tiny box somewhere near your DVM.
I got the idea from here:
Inductance Meter Circuit | Circuit Diagram
The "major" drawback is the test frequency and waveshape, but can probably get you within of a few percent of the number you want in any case. Pretty easily 1% if you're winding or modifying air core inductors.
The inverters can all be from one hex package, they're only different because I don't always use ltspice right.
Old 12th September 2010, 11:29 PM   #18
Oh. If anyone wanted to build that, I used 22uF for the real output filter. The little cap was just so the simulation would settle fast enough on my free computer.
Old 13th September 2010, 08:15 AM   #19
Elvee's Avatar
Here is another DVM adapter for inductance. It's slightly more complex, but has a resolution of 10nH, can have up to 6 ranges, and has a decent rejection of minor parameters (mainly series resistance):
[En cours]Inductancemètre: la version jouet - Forum Projets électroniques
Old 14th September 2010, 02:58 PM   #20
pjp is offline pjp  India
pjp's Avatar
Hi Elvee, if there are no copyright issues, could you please attach the pdf from your link here ?
That forum requires registration to view the pdf, and the registration page is in french (and I don't know french).
how to make this esr meter work with 250uA Panel meter dytln_02 Everything Else 2 27th January 2007 10:13 PM
inductance meter from a cheap meter? jarthel Parts 3 22nd September 2006 05:37 AM
Making a milliAmp meter, become a Volt meter redrabbit Power Supplies 11 26th May 2006 07:51 PM
t-amp vu meter and volt meter question.... rectaacies Class D 7 3rd February 2006 11:22 AM
Copyright ©1999-2013 diyAudio
