| Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators |
#101 | |
Location: Austria, at a beautiful place right in the heart of the Alps.
in case you didn't already implement (did not have time to give it a try nor a closer look) - may I suggest to make 1.) the constant Q "time length" variable and set the time axis of the plot by a (adjustable) factor accordingly This will greatly help to fine tune the analysis to bring up the details of interest, as it worked so well with my PBW analysis - and should be equally beneficial to yours 2) provide a switch that enables plot "file printing" each 1deg to easen animated plot creation ![]() Michael
Audio and Loudspeaker Design Guidelines Last edited by mige0; 8th May 2011 at 07:16 AM. |
#102 | |
Yes, Q is user selectable, as is the time range. For the rotating 3D plot generation, I have script (not in this package) that automatically saves the 360 images in 1 deg intervall, and it takes about 5 min to do (depending on PC). Then only have to manually put the gif images to an animator (easy). - Elias Quote:
Home page If our hearing would be accurate, we would be hearing two loudspeakers. |
#103 | |
I used a FOR loop and the octave PRINT command. Depending on resolution selected it took me up to an overnight run to get the 360 plots of a single analysis calculated. ![]() Michael
Audio and Loudspeaker Design Guidelines |
#104 |
This definitively a major upgrade !
I appreciate already the extension of the plots, but before exploring all the possibilities... it will take time. Elias, thanks for the toy, and don't worry for the fifth dimension. |
| What is pole analysis ? | percy | Solid State | 22 | 12th March 2006 02:03 PM |
| Midrange Analysis | mbutzkies | Multi-Way | 4 | 25th May 2005 01:51 PM |
| noise analysis | tenderland | Tubes / Valves | 5 | 29th March 2005 11:22 PM |
| FFT Analysis | RobPhill33 | Everything Else | 22 | 19th March 2003 07:01 PM |
