Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
BJT Hfe Curves
BJT Hfe Curves
Old 3rd February 2010, 05:59 AM   #21
chrissoo is offline chrissoo  Singapore
Hi
Does anyone have Spice model for 2SA1186 and 2SA1860? These are great transistors from Sanken, unfortunately Sanken does not provide any model.
I would appreciate it very much if someone can direct me to reasonably accurate models.
Chris
Old 15th February 2010, 10:58 AM   #22
hahfran is offline hahfran  Germany
hfe is a constant of a set of differential equations used in 4-pole theory. I.e. is an algebraic equation which is the solution of a differential equation under boundary conditions. It is practically useless to depict hfe in a graph as hfe in frequency domain is complex. Thus all those gain graphs refer to time domain. In practice they are taken pulsed
and are algebraically derived or normalized to constant junction temperature.
Most of these values are not sufficient if one is to compute a lead/lag compensation thus to ensure stability of an amp under various complex loads. Then you'll need the complex four pole parameters to meet Bode conditions or restrictions, resp.
Old 16th February 2010, 03:42 AM   #23
keantoken is online now keantoken  United States
keantoken's Avatar
Within the low audio range I don't think it can be that bad. Worst case I see is outputs, which begin to act up upwards of 10kHz, though some of the pricier ones do wonders.
We are discussing Hfe vs. Ic, but maybe the datasheet makers are confused, and should be saying Beta vs. Ic instead. Maybe it even means different things in different countries. :/
Thanks for your input.
Crissoo, I think I might have heard of models for those on the LTSpice yahoo group, not sure. You will have to sign up though.
- keantoken
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
BJT Hfe CurvesHide this!Advertise here!
PHL Curves - anybody have? Bill Fitzpatrick Multi-Way 3 30th November 2012 10:52 AM
5-125 UL curves anyone? dowdylama Tubes / Valves 2 10th October 2008 11:43 AM
DIY U-L curves Bandersnatch Tubes / Valves 10 1st August 2008 11:00 AM
Derive Triode Curves from Pentode Curves? dsavitsk Tubes / Valves 3 14th May 2007 06:10 PM
Curves, curves, and more curves CarlyBoy Tubes / Valves 5 1st December 2006 10:11 AM
