| Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators |
#81 |
Use the forum search function and lookup the terms laplace ltspice and you will find a few posts. The gist of it is to insert a voltage dependent voltage source (E) whose value is set to a string of the form
laplace ((1+3183u*s)*(1+75u*s))/((1+318.3u*s)*(1+3.183u*s)) You'll have to check the formula above because I wrote it from memory and I don't trust my memory. In ltspice, to set the value of any component you press the CTRL key and in the same time press the right mouse button on top of the component. That will open a dialogue, and you need to change the "value" field. Last edited by ikoflexer; 9th December 2009 at 04:10 PM. |
#84 |
tnx, i'm still a bit "fuzzy" about the use of laplace sources, that helps a lot for me too.
ra7 when you get ready to test your phono preamp with physical test equipment, the circuit i provided above goes in front of the phono preamp (between the sig gen and the phono preamp) and approximates (+/- 0.1db) the pre-emphasis curve of the laplace inverse riaa sig source. |
#85 |
got it unclejed613!
I've actually built the thing and for some reason the top end is down although it simulates well. That's when I thought I should look deeper into the RIAA accuracy. I was using convoluted methods to determine the accuracy. |
#86 |
Hello
How can we see a frequency response graph of an amp with LTspice ? Thank Bye Gaetan |
#87 |
Right click on the input voltage source and enter "AC 1" into the box labeled "AC Amplitude".
Then go so Simulate->Simulation cmd->AC Analysis I usually choose "decade" with 10 points per decade. - keantoken
Contribute to the DIYAudio WIKI! http://www.diyaudio.com/forums/every...p-sign-up.html LTSpice wiki with special attention to new users' troubles |
#88 |
Hello keantoken
It's working Thank a lot Bye Gaetan |
#89 | |
both have references, find them on the web and read them for understanding. |
#90 |
Hola Y'all...
Does anyone have a spice model for a TL431 programable precision reference??? Or know where to find it?? Freezing in SC, Elwood
"when you open your mind to the imposible, soon you will find the truth...." |
| Currently Active Users Viewing This Thread: 2 (0 members and 2 guests) | |
| LTSpice and subcircuits | millwood | Solid State | 12 | 27th April 2011 09:03 AM |
| Using LTSpice | gaetan8888 | Solid State | 6 | 19th July 2007 12:33 AM |
| UcD / LTSpice help | fokker | Class D | 94 | 1st October 2006 01:12 PM |
| Things important to be said..helped by Mr. John Mateus to express things. | destroyer X | Solid State | 22 | 31st July 2006 07:21 PM |
| Ltspice.... | mikeks | Solid State | 10 | 13th June 2004 08:10 PM |
| Page generated in 0.10608 seconds (77.91% PHP - 22.09% MySQL) with 11 queries |
